Disappointed on the dyno results on my stage IV - Road Glide Forums
post #1 of 25 (permalink) Old 03-14-2013, 10:26 AM Thread Starter
Like I expected from the OB the dyno results were less then impressive, but I had him do the dyno tune because it was included in the build price. The bike started out at 75.7 HP and 98.30 torque after the tune it produced 103.82 HP and 106.60 torque, I did put on the Dragula 2 into 1 exhaust and the OB mentioned that it may be the exhaust that is holding the power and torque down. Now I am going to decide on having another dyno done at another facility or spending the money on a Power Vision Pro. Personally I am leaning towards the Power Vision Pro.
post #2 of 25 (permalink) Old 03-14-2013, 11:14 AM
Hullhorr's Avatar
I thought you would have done a little better too! Still not bad though. His comment about the 2-1 exhaust is opposite of what I would think.
2009 FLTR MOP
Hullhorr is offline
post #3 of 25 (permalink) Old 03-14-2013, 11:19 AM
13HDGLIDE's Avatar
dude I didn't go through all these threads about your situation but if you are runnin stock heads stil and got those numbers that's pretty nice IMO and if I'm understanding correct and someone is tellin you that with dragula 2:1 you are restricting the numbers HOLY SHIT is he sorely mistaken !!!!
13HDGLIDE is offline
post #4 of 25 (permalink) Old 03-14-2013, 11:51 AM Thread Starter
SE high performance heads and high compression pistons.
post #5 of 25 (permalink) Old 03-14-2013, 12:10 PM
What's Franks opinion ?
Big_gary is online now
post #6 of 25 (permalink) Old 03-14-2013, 12:26 PM
4getNo1's Avatar
I bet that by now, almost all of us think the OB is FOS anyway so whatever he says about it being the exhaust is probably just more BS. In addition, I don't know if his dyno skills are all that great but I bet he wasn't able to tune her into best performance... was probably also just as glad to see you go as you were glad to leave.
As for your real question (PV versus dyno), I guess it depends upon whether or not you want measured TQ/HP with this configuration versus a way to re-tune and readjust if necessary in the future (more mods?).
My personal preference would be the PV but that's because if I know the engine is effectively tuned, then I don't much need a piece of paper. However, you might want to get some independent numbers to confirm whether or not the OB screwed up tune in addition to the poor initial build.
Recognize that I'm biased, but IMHO go with PV if she's running fine and you can't detect a mechanical flaw.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #7 of 25 (permalink) Old 03-14-2013, 12:29 PM
4getNo1's Avatar
Whoooooo that would a be a good one BG!
Sure do wish I could get a recording of a conversation between Frank and the OB on that "...it may be the exhaust..." topic.
4getNo1 is offline
post #8 of 25 (permalink) Old 03-14-2013, 12:33 PM Thread Starter
Well he thinks for the elevation I had the tune done at (around 2500ft) that it is alright numbers but he thinks the bike could still do better with a correct tune. The bike hit 94lbs of torque at 2500 rpm and breaks 100lbs of toque at 2800 rpm and then it will not drop below a 100lbs of torque until 5400 rpm and it holds the 106 lbs of torque from 3400 to 5000 rpm
post #9 of 25 (permalink) Old 03-14-2013, 12:42 PM
tdkkart's Avatar
I think with 255 cams the numbers aren't bad at all, in fact the cams may be holding back the performance of the SE heads, ie: the heads are capable of alot
more performance than the cams.
tdkkart is offline
post #10 of 25 (permalink) Old 03-14-2013, 12:43 PM Thread Starter
Well I know I wasn't going to get a good tune from OB and now the bike does some popping on decel around 3000 rpm and then again at 2200 to 2000 rpm. The OB basically put in a canned mapp and then tried to fine tune the AFR which he didn't do a good job at IMO.
Disappointed Dyno numbers on cam build Skull Engine Related 43 01-22-2016 07:48 PM
13 RCG Stage 1 Dyno results lvyper876 Dyno Results 6 03-29-2015 04:01 PM
Disappointed in Dyno Results SMSgt B Dyno Results 30 12-01-2014 09:31 AM
Disappointed in my stage IV build ironmark Engine Related 45 02-10-2013 07:54 AM
RGU Stage One Dyno number results ichiban Intake and Exhaust 5 07-03-2011 12:36 PM
