16k and The Cases are Split - Road Glide Forums
post #1 of 25 (permalink) Old 03-15-2013, 07:46 AM Thread Starter
mitchdm's Avatar
So a week ago I leave on a little ride ~ at less than 16k I have a knock in the bottom end ~ check the compensator ~ chain ~ all good here. Take it to the boutique and the bottom end is the culprit ~ crank pin or rod bearings ~ I can tell you reassambly will include Timken Bearing conversion, Lefty Bearing, Crank Trued, plugged, welded.... Downside is I won't be riding for a month or so ~ upside is that a more dependable platform when complete.... The bike is less than six months old and I understand these things happen just a little frustrating.
mitchdm is offline
post #2 of 25 (permalink) Old 03-15-2013, 07:51 AM
qkshift's Avatar
Damn sorry to hear and riding season is just starting.Hoping you get it back soon better then ever
qkshift is offline
post #3 of 25 (permalink) Old 03-15-2013, 08:08 AM
I assume the work is being done under warranty with you just paying for the extra parts?
post #4 of 25 (permalink) Old 03-15-2013, 08:10 AM Thread Starter
mitchdm's Avatar
Thanks Qkshift ~ I ride all year ~ fortunately ~ thinkin about a month or so to get it back. Going to make sure that all products goin back in are a step up from the stock build ~ Goin with Darkhorse crankworks crank, gonna bore to 113 and do the cp pistons/rings ~ Whole bottom will be new except the cases. Just will be going nuts with the wait...
mitchdm is offline
post #5 of 25 (permalink) Old 03-15-2013, 08:13 AM
Looks like your paying to have the work done, why not go bigger than 113, the cost won't be much different.
post #6 of 25 (permalink) Old 03-15-2013, 08:35 AM Thread Starter
mitchdm's Avatar
This is correct ~ so in a way this is a stroke of luck
mitchdm is offline
post #7 of 25 (permalink) Old 03-15-2013, 10:23 AM
Shark of the Quarter Apr-Jun13
Ugh. Sorry to hear that. However now is the time to upgrade while she is down...
2012 RG Custom CVO "Skunk" Construction Complete
Cmathias is offline
post #8 of 25 (permalink) Old 03-17-2013, 09:19 PM
What are you going to do with the old parts? I'm sure you're not going that far and put the 259s back in.
HeatWave is offline
post #9 of 25 (permalink) Old 03-18-2013, 09:28 PM Thread Starter
mitchdm's Avatar
Goin with the Woods 777's ~ I'll check on the 259e's ~ thinkin there may have been some metal in the bottom end ~ I'm going with a darkhorse crankworks crank/flywheel (SE trued, welded, plugged and balanced for the 113" C&P Pistons. Feuling Camplate/Oil Pump/Zippers cam chain tensioners/ woods 777's, boring the jugs and a set of worked heads ~ should be a good solid motor puttin out 120+Hp and 125+TQ ~ I just want a solid platform to go with the Baker DD7 ~ I'll let ya know on the cams...
mitchdm is offline
post #10 of 25 (permalink) Old 04-06-2013, 12:36 AM Thread Starter
mitchdm's Avatar
I could go bigger but in my small brain ~ the bigger I go the more stuff I can break ~ my goal is 100k motor (2-2.5 years for me) ~ Just want a nice mix of power & dependability ~ This thinking may be wrong but I would be happy if I am at 120+hp and 125+tq ~ So you are probaly right dbel ~ but I'm already headed down the path and hope to do some ridin with ya in South FL ~ SemperFi
mitchdm is offline
New Cases CR3999 *General Road Glide Discussions/Pictures 10 04-25-2013 11:43 PM
Mental Cases staush General Off-Topic Discussions 5 12-14-2012 09:06 PM
09 strret glide engine cases rio1012006 Engine Related 1 09-04-2011 02:34 PM
Top cases Glideman07 Aftermarket Accessories 1 09-03-2011 12:26 AM
New cases pte359 *General Road Glide Discussions/Pictures 0 07-02-2011 12:05 PM
