Cam Tensioner after only 13k!! - Road Glide Forums
post #1 of 5 (permalink) Old 03-16-2013, 11:43 AM Thread Starter
Gonekat's Avatar
While cams were being done, mech replaced the tensioner. Its pretty bad after only 13k
2011 RGC, Sedona Orange 103" w/ 48H cams,PM Icon 21" wheel,Kury Mach 2 intake,Jackpot 3.5, PM brake and shift levers, CB 14" TRSSC shield, Sinister 14" apes, custom levers.Black exhaust,floorboards,pegs and crash bar.
Gonekat is offline
post #2 of 5 (permalink) Old 03-16-2013, 11:46 AM
Harleyagain's Avatar
Damn, that certanly does not look good. Ahhh bit on the tight side! I just did my cams at 7500, she was nice and smooth but makes you wonder about others who do not replace their cams
Bob
Harleyagain is offline
post #3 of 5 (permalink) Old 03-16-2013, 11:49 AM Thread Starter
Gonekat's Avatar
I talked to a buddy with a SG w/ 32k on it. Never had cam chest open. He says it just moved up in the list of things to do
Gonekat is offline
post #4 of 5 (permalink) Old 03-16-2013, 11:53 AM
Bigtrev8xl's Avatar
It's bedding in,when the center section of the chain makes contact with tensioner the wear rate will slow down.
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #5 of 5 (permalink) Old 03-16-2013, 01:14 PM
Did he measure your pinion runout, while he was in there. Don't know if there's any correlation with runout/shoe wear on the hydraulic tensioners. Maybe one of the builders whose seen hundreds of these things will chime in. My runout is about .0025", and at 25k miles, I just had shiny spots for shoe wear, virtually none.
BTW, looks like your 103"/48H combo turned out real nice....bet it's fun to ride now!
Jeff
akjeff is offline
Is there still a cam tensioner issue mr_reality Engine Related 24 04-11-2014 06:23 AM
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 08:47 AM
TC88 Cam/Cam tensioner advice zglide2003 Engine Related 2 08-31-2012 12:01 PM
Hydraulic chain cam tensioner kit ohd24 Engine Related 7 06-30-2012 08:24 AM
Cam chain tensioner question SKULLZ *General Road Glide Discussions/Pictures 5 05-14-2011 03:29 PM
