New to Dyno and HP numbers - Road Glide Forums
post #1 of 10 (permalink) Old 03-19-2013, 08:56 AM Thread Starter
Deadstroke's Avatar
So not sure what stock is but I put it on the dyno a few days ago and numbers came back with is
75hp
89torque
I have haleys hi-flo, powervision, and 2 in 1 pipes from frank.. is that good numbers for a 2013 RG?
Thanks
Deadstroke is offline
post #2 of 10 (permalink) Old 03-19-2013, 09:15 AM
Those numbers are normal, if you stick a cam in there you can go up at least 10% on each, and that's being conservative.
post #3 of 10 (permalink) Old 03-19-2013, 09:36 AM
mocotom's Avatar
I would agree with dbell66253. With the parts you already have, the correct cam will make a holy sh#t difference.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #4 of 10 (permalink) Old 03-19-2013, 01:20 PM Thread Starter
Deadstroke's Avatar
OK great so far I am on the mark Cams hmm which ones?
post #5 of 10 (permalink) Old 03-19-2013, 01:40 PM
hd4cruzin's Avatar
Those #'s seem low to me. I have a 2012 FLTRX that I put a FullSac 2-1-2, Fullsac baffles in stick cans, SE A/C and TTS with a Map from Steve.
Dyno numbers were 77HP 96TQ.
2012 FLTRX BBP
hd4cruzin is offline
post #6 of 10 (permalink) Old 03-19-2013, 01:40 PM
Rkfltrx's Avatar
Depends on how you ride. I went with TW-222's because I wanted more low end TQ. With the 2-1 you have I would call Frank and let him set you up!
SOLD:
2012 FLTRX Denim Black,Stock head pipe with Cat removed w/ Jackpot 4" black slash up slip-ons. power vision, Fuel Moto pro billet A/C, Woods TW-222's, 12" Klock Werks . Sanchos Wings. Khrome werks 2+2 Handlebars.
Rkfltrx is offline
post #7 of 10 (permalink) Old 03-19-2013, 02:04 PM
mailman's Avatar
Re: New to Dyno and HP numbers
I haven't had my RG on the dyno yet, but my Sportster 1250cc puts out 75hp/77tq (mild cams, k&n air filter, open pipes).
It seems like a 103ci should be outputting more then that?
Sent from Motorcycle.com App
Billy
mailman is offline
post #8 of 10 (permalink) Old 03-25-2013, 03:59 PM
Here are my numbers for a '13 RG CVO with 110", 255 SE cams, heads flowed, larger intake and exhaust valves, Cometic head gasket and adjustable push rods. Only have 10.2:1 compression so the bike is very reliable for the long run. 101 HP and 124.77 torque. notice the torque curve starts at 2,000 and stays hard until almost 5,000 RPM. Those that get big torque and HP numbers are usually sacrificing the low-end off the line torque and make up for it around 6,000 RPM but who runs at those R's?.
Ride it like you stole it!!
'13 CVO Road Glide Anniversary
Batbiker is offline
post #9 of 10 (permalink) Old 03-25-2013, 04:24 PM
tsmartt's Avatar
Frank will probably recommend the TMan 555TQ cams. He has dyno sheets on a setup close to yours. I am running Dragula 2:1 with a TMax tuner. TMan cams are going in next week, per Frank's recommendation. Looking for mid-90's HP and low 100's torque. Can't wait to twist the throttle on those new cams!
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #10 of 10 (permalink) Old 03-26-2013, 08:22 AM Thread Starter
Deadstroke's Avatar
Cant wait to hear your results, keep me posted if you dont mind
Help HP not geting the numbers 110 tire shredder bigmatt1967 Engine Related 12 04-20-2017 06:44 AM
Finally have my dyno numbers on cam install FLtroll Engine Related 18 11-04-2014 12:03 AM
5sp HP vs 6sp HP sj01fltri Engine Related 11 12-29-2013 08:42 PM
What kind of hp-tq numbers for a good stage 1 dyno-tune McGruder ECM/Fuel Management systems 13 08-12-2013 09:22 PM
Any Ideas on what Torque/HP numbers I can expect? AZroadrunner Engine Related 12 04-09-2011 01:19 PM
