My CVO 110" '13 back from Doc's - Road Glide Forums
post #1 of 6 (permalink) Old 03-19-2013, 08:17 PM Thread Starter
Just picked my bike up from Doc's. He is a genius! I tried to push him to change the 255 cams but he said if I want low to mid range torque I should keep them. Doc had T-Man flow the heads, new intake and exhaust valves, adjustable push rods and cometic head gasket with the TTS tuner. I already had the Fat Cat 2 into 1 pipes installed. This baby will run. I'm getting 124.77 Ft/Lbs of torque and 101 HP SAE. Torque curve starts at 2k RPM with 105 and climbs to 124.77 at 3.75k RPM and doesn't fall off until after 5k. I will post the dyno chart tomorrow.
Ride it like you stole it!!
'13 CVO Road Glide Anniversary
Batbiker is offline
post #2 of 6 (permalink) Old 03-19-2013, 08:56 PM
Sounds like you may go and pull a few stumps out of the ground...glad you liuke it, I bet it feels a bit different.
post #3 of 6 (permalink) Old 03-19-2013, 10:26 PM
rageglide's Avatar
Probably going to need a backrest for the passenger in your sig....
rageglide is offline
post #4 of 6 (permalink) Old 03-19-2013, 11:04 PM
Rowdy's Avatar
Sounds like fun.
Ride safe.
Rowdy
Rowdy is offline
post #5 of 6 (permalink) Old 03-21-2013, 09:32 AM
riptilyaflip's Avatar
I going the direction you started; Replacing the cam on my 110 with a T-Man 600, leaving the heads and compression stock for now. Will probably do the T-Man heads and pistons later, depending on how it turns out. Before new cam, but with Power Duals, Monster Rounds, Rolland Sands A/C, and a Thundermax Tuner it ran 95HP and 111 TQ. That was without any Dynotuneing, parts were already on from dealer, wanted to see where we started before the cam and Dynotune. This will be a interesting comparison.
riptilyaflip is offline
post #6 of 6 (permalink) Old 03-21-2013, 09:36 AM
TimMCc's Avatar
I would love to have that torque, especially when loaded and riding two up with the lady.
Hold fast!
TimMCc is offline
'13 CVO RG from Doc's and T-Man Batbiker Dyno Results 5 06-07-2014 12:24 AM
Doc is a genius - 110" CVO '13 build Batbiker Dyno Results 4 03-22-2013 02:11 PM
Best engine upgrade for 110" '13 CVO? Batbiker Engine Related 28 01-25-2013 08:36 PM
SE Stage 4 for SE 110" '13 CVO RG Batbiker Engine Related 2 01-19-2013 12:22 PM
