130+ hp help - Page 3 - Road Glide Forums
 17Likes
post #21 of 35 (permalink) Old 04-27-2017, 06:18 PM
unbalanced's Avatar
Originally Posted by Smarty View Post
Put an extra medium belle view washer against the other medium ones the same direction behind the compensator. Then you use the Harley automatic tensioner and you will be good to go.
Measure before doing this to find out where you are with the stack height. Blindly putting it in may put you outside the spec.
-Unbalanced
He who laughs last thinks slowest.
unbalanced is offline
post #22 of 35 (permalink) Old 04-27-2017, 08:43 PM Thread Starter
Thank you for all the feed back. My initial thought was a solid sprocket but then I dont want to save comp damage at the expense of trans damage. Then I thought maybe if I use a Hayden m6 that would help insulate trans but judging from a few post back that wouldn't work well either. The best solution would be to take some power away but what fun is that lol. Did that darkhorse comp ever materialize that was being talked about?
drnovaman is offline
post #23 of 35 (permalink) Old 04-28-2017, 01:17 AM
You're Kidding?? Right???
HeatWave is offline
post #24 of 35 (permalink) Old 04-28-2017, 07:18 AM
Smarty's Avatar
This puts you right where you need to be. It allows the compensator work just as the ones from the evo days up to 06. It allows it to move but not make it to the tip where all the problem has been and the noise. I've put this in bikes where the comps were knocking like hell and quietened them down and no more issues after 20,000 miles.
tj316 and Hillsidecycle.com like this.
2016 RGS Black Quartz
Smarty is offline
post #25 of 35 (permalink) Old 05-17-2017, 05:38 PM Thread Starter
update
Well as of now I have a screaming eagle compensator with an extra spring in it. Nasty noises are all but gone in it can even hear my noisy valve train again lol. Also went back to stock tensioner as it works well with my 49 tooth clutch basket. Been keeping as eye on it and doesn't appear to be over adjusting but haven't gotten too stupid with it. Making sure everything is warmed up be fore laying into it. Most likely going to end up with a gear and no comp. Look in classifieds if you are looking for a baker comp and attitude adjuster as I am going to list them for sale. Both brand new. Thanks for every ones help dealing with my problems.
post #26 of 35 (permalink) Old 05-19-2017, 09:12 AM
unbalanced's Avatar
Ride one with a gear, wasn't for me, hands went to sleep really fast. Trade offs.
-Unbalanced
post #27 of 35 (permalink) Old 05-22-2017, 06:01 AM
With a rubber mounted engine, or c/balanced Softail, the rider is isolated from the engine.
Solid sprocket will end all comp sprocket issues.
Scott
Hillsidecycle.com is offline
post #28 of 35 (permalink) Old 05-22-2017, 04:48 PM Thread Starter
Scott
Not to worried about vibration, heck as tight as I have my comp shimmed its damn near a solid gear now at cruise. And not worried about engine has a S&S crank and rods and all good components. What I am worried about is that weak trans output bearing and I have yet to come up with a tensioner I feel good about.
post #29 of 35 (permalink) Old 05-22-2017, 06:55 PM
The current SE Comp in "The Short Bus" is "shimmed",,, I can feel the difference...
"The Short Bus" is approaching 60k mi. on the OE Tensioner,,, The Chain is always within spec when checked,,, Minimal wear on the Original Shoe...
Just get the Primary up to Operating Temp,,, Then Bang Away (A little Rev-Matching on Downshifts doesn't hurt either...)
Check it every now and then until you get a comfort level...
HeatWave is offline
post #30 of 35 (permalink) Old 05-22-2017, 07:14 PM Thread Starter
I paid heed to your advice in earlier post and have been doing just as you suggested. Have checked it a few times with no sign of it tightening from my initial setting. I am thinking my next trip into primary cover I will remove medium extra spring and add another large one and give that a try but for now its no worse then it was at a 107 and I put nearly 15000 miles on like that.
Help HP not geting the numbers 110 tire shredder bigmatt1967 Engine Related 12 04-20-2017 05:44 AM
5sp HP vs 6sp HP sj01fltri Engine Related 11 12-29-2013 07:42 PM
What front fender are you guys running? I just got my 21" SMW wheel w/ HD 130 tire 13-FLTRX Paint & Bodywork Section 42 01-01-2013 09:00 PM
2008 RG for 5'3" 130# wife?? ncbeast *General Road Glide Discussions/Pictures 15 03-06-2011 07:22 AM
