Dropped rear cylinder - Road Glide Forums
post #1 of 13 (permalink) Old 03-25-2013, 02:10 AM Thread Starter
motosig102's Avatar
While down at bike week in daytona a buddys bike dropped the rear cylinder and then died. Upon startup again it sounded like it had no oil in the motor. Took it to the local dealer and they said that was normal and it was a safety measure built into the bike? Has anybody else experienced or heard of this? What are your suggestions?
motosig102 is offline
post #2 of 13 (permalink) Old 03-25-2013, 03:35 AM Thread Starter
motosig102's Avatar
Re: Dropped rear cylinder
Add on: It is a 2013 custom.
post #3 of 13 (permalink) Old 03-25-2013, 04:28 AM
4getNo1's Avatar
The new HDs have an automated rear cylinder shut-down when engine temp goes too high (a good idea, especially with 103"). This feature is activated if you twist the throttle backwards while sitting. Were y'all sitting still for some time waiting for traffic to clear so you could move again (or something like that)?
If you think that's probably the situation, then it's not supposed to make the engine die so the dealer didn't account for this. Your bud should probably go back and make them look into why the engine conked out instead of merely shutting down the rear cylinder... plus...
It's not good to let an air-cooled engine get so hot that this new safety feature is activated (the Main Street crawl can get'cha ). I hope your buddy didn't just keep letting her run on and on until she finally died even though the new feature had tried to reduce hazard to the engine.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #4 of 13 (permalink) Old 03-25-2013, 05:01 AM
torqu's Avatar
I thought it was activated when rolled forward. If you rolled it back you would just rev up the motor.
torqu is offline
post #5 of 13 (permalink) Old 03-25-2013, 06:25 AM
Harleyagain's Avatar
I thought it was an auto feature once it is turned on you do not need to roll it forward each time to activate it.
Bob
Harleyagain is offline
post #6 of 13 (permalink) Old 03-25-2013, 06:31 AM
JacktheBagger's Avatar
you dont have to activate or deactivate for each use
set it on or off
JtB
2011 Ultra
JacktheBagger is offline
post #7 of 13 (permalink) Old 03-25-2013, 07:03 AM
4getNo1's Avatar
set it on or off
JtB
Thanks JtB... I forget about that. In fact, I can't remember if you need to set it each time you come to a stop, each time you start the engine, <whatever>. I also didn't clearly explain that, to me anyway, "backward" was opposite to the direction a rider typically forces the throttle grip. I probably should have said "Read the manual to make sure..." someplace since it's indeed not a truely accurate or totally complete summary.
4getNo1 is offline
post #8 of 13 (permalink) Old 03-25-2013, 07:16 AM Thread Starter
motosig102's Avatar
Yes it was due to idle and no he didnt just keep letting it go till it died it just died shortly after the cylinder shut down from my understanding. I wasnt there to say for sure I just posted this for him. However with the vast knowledge of this group I figured this would be the best place to get a second answer.
post #9 of 13 (permalink) Old 03-25-2013, 07:34 AM
4getNo1's Avatar
<snip> no he didnt just keep letting it go <snip>
Outstanding .
Then I stand by my original suggestion - your bud should probably make 'em explain why she died instead of merely going into the parade mode.
4getNo1 is offline
post #10 of 13 (permalink) Old 03-25-2013, 08:43 AM Thread Starter
motosig102's Avatar
Thanks I'll let him know and probably have him take it to the other dealer as well.
WTB: front brake master cylinder/clutch master cylinder 93-331-29psi Wanted! (Buy or Trade) 3 09-26-2014 03:46 PM
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 01:07 PM
WTB stock rear brake master cylinder Swagzilla Wanted! (Buy or Trade) 2 06-28-2012 06:10 PM
Rear Cylinder misfire blkbusa Troubleshooting for Road Glides 10 02-14-2012 03:56 AM
Rear cylinder kill opt. Big_gary *General Road Glide Discussions/Pictures 20 03-05-2011 09:02 PM
