SE cam bearings? - Road Glide Forums
post #1 of 4 (permalink) Old 03-30-2013, 06:30 PM Thread Starter
SE cam bearings?
Heres a couple photos of the SE cam bearings I just bought. I had read they were Toyo/ Timken but they are now INA's. Would you run them?
10' Denim Black FLTRX, 103ci, ported, Dragula, Andrews 54H, Power Vision, 15" apes, blacked out.
68 EB is offline
post #2 of 4 (permalink) Old 03-30-2013, 10:10 PM
rageglide's Avatar
Sure! It's a full complement bearing. No Cage, meaning almost 2x the bearing surface.
INA is a bearing company. Just like Timken, FAG, Toyo, Kyoto, and of course Torrington. INA is a highly regarded German company.
INA got a bad name in the Harley community because the *caged* bearing was used in Evo motors vs the full complement Torrington INA bearing that was being used previously. (This same mistake was made in the Shovelhead era too... ) On paper the INA was the right bearing, but in reality the full complement proved far superior at handling the loads that 4 valve springs and RPM presented. Harley lost a lot of trust with this, especially when it became clear that the INA bearing was failing with stock cams too... which proved it was the wrong choice. But they never came back and said, ok, yeah we fuked up... (Have they ever admitted mistakes, and there are many. We're so blind... :-) )
But fool me once, shame on you, fool me twice, shame on me... Full complement is cheap insurance... :-)
rageglide is offline
post #3 of 4 (permalink) Old 03-30-2013, 11:35 PM Thread Starter
My thoughts exactly, HD is the culprit for specing out the bearing for their own application not INA. I noticed the ends of the needles are necked down in comparison to the other full compliment bearings I've seen are full diameter the entire length. Regardless they are going in tomorrow.
68 EB is offline
post #4 of 4 (permalink) Old 03-30-2013, 11:53 PM
rageglide's Avatar
Torringtons look exactly the same. I have Kyoto's which look the same. That little neck down is the retention 'mechanism'.
110 best cam using SE cam Yellow09SERG Engine Related 10 12-07-2015 12:53 PM
Is replacing cam bearings necessary? BigNorm Engine Related 20 07-02-2015 08:40 AM
Installing new cam bearings Stag556 Engine Related 10 09-14-2014 03:31 PM
Replace cam bearings with 362 miles? Eshaw301 Do-IT-Yourself 14 05-20-2012 11:40 PM
SE Air cleaner assm for 2000 SE Road Glide 2blackbelts Aftermarket Accessories 2 11-11-2010 12:12 AM
