Anyone using the S&S 510c cam in your bike? - Road Glide Forums
post #1 of 14 (permalink) Old 03-31-2013, 12:41 PM Thread Starter
yzernie's Avatar
Question Anyone using the S&S 510c cam in your bike?
Looking to put cams in my 2011 RGU w/103. For the riding I do, mostly highway riding and some two-up, I like the power delivery numbers of the 510c. I have a V&H Power Dual headpipe mated to 4" Rinehart mufflers, a SE Stage 1 a/c and the HD Stage 1 ECM upgrade. I'll be adding the SEPRT at the same time as whatever cams I decide on. Does anyone have the 510c's in their bike that can give me a real life eval?
Thanks in advance!!
The satisfaction of a job well done is to be the one who has done it - Lou Holtz
yzernie is offline
post #2 of 14 (permalink) Old 03-31-2013, 01:06 PM
Triplej's Avatar
Check with member Jimmyray- https://www.roadglide.org/member.php?u=3891 - he has them but I think his is a 96". I love how his bike sounds.
Triplej is offline
post #3 of 14 (permalink) Old 03-31-2013, 01:22 PM Thread Starter
yzernie's Avatar
Was reading some other threads and saw he had them in his bike. I sent him a PM...prpbably while you were typing this reply!!!! Hope to hear from him and get his opinion.
Talking to my tuner, he says the 510 in the 96 or 103 is ok. He pushes the S&S 570 but I want a little more lower rpm torque than the 570 offers.
yzernie is offline
post #4 of 14 (permalink) Old 03-31-2013, 08:05 PM
jimmyray11349's Avatar
I know nothing about cams but based on my riding habits this was recommended by my indy, who is very knowledgable and has a great reputation.
i am not a knee dragger but ride mildly agressive (for a GEEZER). I do a lot of 2 up.
the cam comes on at about 2500 and pulls strong to redline (6250). i have not put a stop watch on it but it seems from a roll off to 90 mph in about 5-6 seconds in 3rd gear.
my mileage did drop, as my indy said it would from 42-43 to 34-35. some of that could be due to more throttle = more fun. however oil temps dropped by about 25=30 degrees with cam install.
PM sent also
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #5 of 14 (permalink) Old 04-01-2013, 06:51 AM
I'd take the .570 hands down, and twice on Sunday, over the .510.
Jim Kennedy, of Paradise Performance, Matoon, Ill, tuned one of our 98"/Stage II Heads/.570 combo with Rinehart duals, OE t/body.
108 hp/115 ft/lbs while being set at 10.0 cr, torque being "all in" by 3500 rpms.
Scott
Hillsidecycle.com is offline
post #6 of 14 (permalink) Old 04-01-2013, 07:56 AM
caboverbob's Avatar
I have the 510G in my vintage '01 RG with T-Header, big sucker, and Terry tuner 88" and it does pull to redline. No knew dragging, but I do like to twist the throttle.
Peace
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #7 of 14 (permalink) Old 04-01-2013, 08:17 AM
prodrag1320
Guest
Posts: n/a
i agree 100% with scott,we use alot of S&S cams,we`ve used the .510 with customers just wanting to go with gear drives cams,but the .570`s are one of our favorites here.probley the best all around cam for milder builds (& they can still pack quite a punch on more aggressive builds too)
post #8 of 14 (permalink) Old 04-01-2013, 08:59 AM
I'm not an engine expert by no means, when my bike was pushed out to 107 last year the person doing the work uses mostly S&S cams and convinced me to go with the 570G, I've been very happy. I asked about the 510 and a couple of others and was told for my build the 570 would be better. I don't know how the others work, but I have plenty of low end tq and she pulls all the way to redline, also have a couple of my buddies who ride Suzy M109s who are no longer able to leave me, and 1 partner on a SE 110 who I can leave anytime I feel like it.
post #9 of 14 (permalink) Old 04-01-2013, 12:30 PM Thread Starter
yzernie's Avatar
My motor is stock with the exception of the external add on items listed in my op. I don't want to get into a bunch of head work, compression increases and whatnot but just want a little bit more oooomph when we are two up.
I'll listen to other suggestions as well. This is my first HD and willing to learn from the folks that have real experience!!!
yzernie is offline
post #10 of 14 (permalink) Old 04-02-2013, 07:03 AM
2 options for outstanding power in plug/play cams.
Wood 222's, or Andrews 48.
Scott
110 best cam using SE cam Yellow09SERG Engine Related 10 12-07-2015 12:53 PM
Would like your suggestions: Hiding wires & docking post when using solo seat ndronet Seating: seats, backrests 3 10-06-2014 12:26 PM
Anyone using "Focal" component set up with Rockford Fosgate 300 amp? Valduzy Audio 2 04-04-2014 02:13 AM
FS: S&S 510C Cams Dickie Sold 2 12-15-2012 03:14 PM
Anyone using a S&S high flow air cleaner Hawkeyestoob Road Glide Specific Discussions 9 08-13-2011 10:07 AM
