100 HP Club - Road Glide Forums
 6Likes
post #1 of 25 (permalink) Old 04-05-2013, 09:54 PM Thread Starter
cwdouble's Avatar
100 HP Club
Ok guys I have basically a bone stock 2011 RGU. (Stage one..heavy breather and rhinehart slip-ons). I am wanting 100 HP and about 115 torq. I have been told with just a change of cams, tune, exhaust I can pretty much get one HP per cubic inch with out changing pistons and/or head work. I was just wondering those of you that are pushing 100+ HP what set up are you using? Just trying to get ideas.
cwdouble is offline
post #2 of 25 (permalink) Old 04-05-2013, 10:03 PM
Hullhorr's Avatar
Do you have a 103"? If so just a cam swap should get you real close. I have a 96" with a 107" kit and T-man 555tq cams and I dyno'd at 95 HP, and 118 TQ. I think the HP could be better and I'm going to do another dyno this summer to see.
2009 FLTR MOP
Hullhorr is offline
post #3 of 25 (permalink) Old 04-05-2013, 10:07 PM
S&S 124" 136hp pretty sure this combo will get you where you want. lol
glide69 likes this.
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #4 of 25 (permalink) Old 04-05-2013, 11:39 PM Thread Starter
cwdouble's Avatar
I am sure that would get me where I want to be. Maybe after I run this one into the ground and have no choice but to replace this motor.
cwdouble is offline
post #5 of 25 (permalink) Old 04-05-2013, 11:41 PM Thread Starter
cwdouble's Avatar
Hullhorr yes I do have the 103.
cwdouble is offline
post #6 of 25 (permalink) Old 04-05-2013, 11:49 PM
mitchdm's Avatar
Cams, Tuner/Tune, Exhaust, & Breather ~ will get you so close ~ maybe even break the 100hp mark ~ If memory serves me to finally get over the hump ~ I did the heads....
mitchdm is offline
post #7 of 25 (permalink) Old 04-05-2013, 11:56 PM
maddog69's Avatar
I like the idea of the 124" Once this one gets tied or blows up.
maddog69 is offline
post #8 of 25 (permalink) Old 04-05-2013, 11:57 PM
connector's Avatar
Agree with Mitch i think if you want to punch over the 100 mark you got to do the heads for a strong reliable build.
09 FLTR 103 Stage III
connector is offline
post #9 of 25 (permalink) Old 04-06-2013, 06:29 PM
GoodmanHD's Avatar
I did a fuel moto 107 with level b heads, 777 cams and 10.5 pistons. I opted for the reworked throttle body for a little more out of it. It's a pretty cost effective way to do it. Fuel moto will buy your stock heads and jugs back. I made 113hp and 127 tq with a drago 2-1.
If you do the cams, breather, exhaust and tuner....you're almost there. I'd definitely recommend the head work. And while you're there a little bump in compression pistons will make it a new bike. Compression is the only way to get hp AND tq at the same time!
SteadyEddie likes this.
-GOODMAN
08 SHARK
96 HERITAGE
96 WIDE GLIDE
94 ROAD KING
IF EVERYTHING IS UNDER CONTROL, YOU'RE GOING TOO SLOW!
GoodmanHD is offline
post #10 of 25 (permalink) Old 04-07-2013, 03:56 AM
equandt's Avatar
I have a FM107 kit with TW-555 cams in my batwing. See the attached dyno sheet. It has the power levels you are looking for.
You can get close to 100HP / 115 TQ with just a cam change, but make sure you don't over cam it just to hit 100HP on the big end. For my RGC I'm looking at the TW-222 in my 103. I expect around 95 HP / 110 TQ with my Rinehart Extreme duals and SE Heavy Breather.
Check Fuel Moto's website or the Wood website for some dyno sheets of different cam only builds. Dragos or Hillside could also give you some help but I am not as familiar with their work.
Good Luck
2012 FLTRX
2010 FLHTCU
equandt is offline
Looking for 100 hp and 115 torque for under 1500.00 sfcusaret2004 Engine Related 13 04-21-2017 12:29 PM
I am Done - Joining the 100+ HP Club SteadyEddie *General Road Glide Discussions/Pictures 106 08-26-2016 03:14 PM
5sp HP vs 6sp HP sj01fltri Engine Related 11 12-29-2013 08:42 PM
New Strip Club Anthem NakedSnowman General Off-Topic Discussions 3 11-04-2010 12:33 AM
Motorcycle Club Riding and Club Education BDMastiff General Off-Topic Discussions 3 10-07-2010 03:34 AM
