Help with a 30 tooth swap - Road Glide Forums
post #1 of 10 (permalink) Old 04-08-2013, 05:56 PM Thread Starter
nas7yn8's Avatar
I have a 2009 road glide and wanted to change to a 30 tooth front pulley The question I have is. Do I have to change the belt or can I use. The stock belt And if you have done this swap how do u like it
Thanks again
nas7yn8 is offline
post #2 of 10 (permalink) Old 04-08-2013, 07:09 PM
There are 2 options that I know of:
1) Change the belt to 1 tooth smaller
2) Grind out the holes on your swing arm and add a 1/2" block to the adjuster boss.
I just bought a 30tooth for my bike and waiting on it. One of my Brothers did a 30tooth on his nightrain and it made a big difference on the take off and made shifting into 6th gear at 70mph without lugging the engine.
Jims79FLH is offline
post #3 of 10 (permalink) Old 04-08-2013, 07:56 PM
Desertwndrr's Avatar
http://www.cvoharley.com/smf/index.php?topic=67516.0
I changed my front pulley to a 30 tooth and changed out the belt to a 139t Gates Polychain. I did save the stock belt and when he time comes I will mod my swingarm as is described in the thread that I linked to.
The swap to a 30t pulley is definitely worth it!
Desertwndrr is offline
post #4 of 10 (permalink) Old 04-08-2013, 10:21 PM
Thanks for that link, very helpful. Glad to clear up the bad info I was given.
post #5 of 10 (permalink) Old 04-08-2013, 10:22 PM
i did the swing arm mod and used stock belt with 30 tooth. i used link desert posted. it was pretty easy im happy with the results so far i dont have to many miles on it yet
jsdmax is offline
post #6 of 10 (permalink) Old 04-08-2013, 10:41 PM
If you do your own work and can round up a socket this can be less than a $100 mod and it is so well worth it. I got my pulley from Lakeshore for like $69. It is a stock Tri-Glide pulley.
post #7 of 10 (permalink) Old 04-08-2013, 11:36 PM Thread Starter
nas7yn8's Avatar
Thanks for the info
nas7yn8 is offline
post #8 of 10 (permalink) Old 04-09-2013, 10:55 AM
JacktheBagger's Avatar
I'm not a member at CVO , so I spose that is why I am not seeing pics
I like the idea as you retain the cruise , I considered doing the compensator/clutch hub re gear but with that you lose the cruise control
Is the tri glide belt one tooth shorter than our belts ??
JtB
2011 Ultra
JacktheBagger is offline
post #9 of 10 (permalink) Old 04-09-2013, 12:45 PM
I'm not sure about the Tri-Glide belt, but the pulley is a 30t as opposed to our stock 32t pulley. I did retain the cruise control. With my TTS tuner I was also able to readjust the speedo for the gear change and my odometer is spot on accurate. Verified with a GPS. I think that the Power Vision and the TTS tuner are the only tuners that can adjust the speedo.
It is worth it to join the CVO forum. Lots of great stuff there.
post #10 of 10 (permalink) Old 04-09-2013, 02:23 PM
I guess I should have re worded that , I wonder if the tri glide belt will work , the wheelbase would be the issue naturally
seems I read somewhere that it does work
JtB
2011 Ultra
30 tooth conversion MightyWhitey Engine Related 31 01-31-2019 06:48 PM
30-60-30 bfscratch26 *General Road Glide Discussions/Pictures 16 05-16-2015 08:41 PM
30 Tooth Drive Pully Modification Seabee Engine Related 29 09-19-2012 08:07 PM
Baker 30 or 31 tooth trans pulley????? gabbyduffy Engine Related 36 07-23-2011 02:12 AM
66 Tooth Ring Gear DAK47 Engine Related 4 01-08-2011 01:22 PM
