Oil Cooler/Fans!!! - Road Glide Forums
post #1 of 17 (permalink) Old 04-15-2013, 01:48 PM Thread Starter
Q-Hog's Avatar
Oil Cooler/Fans!!!
Does the oil cooler w/fans really works & is it worth the purchase? I found two companies that sell similar setups, Jagg & Ultra Cool. Any input on these?
Q-Hog is offline
post #2 of 17 (permalink) Old 04-15-2013, 02:31 PM
skototrot19's Avatar
Q,
Check out Wards Parts Werks
Dude is WAY into cooling/heat management and has designed thermostats and forced air fans that cool directly where needed. I know that it's not directly what you were asking, but thought I'd throw something into the mix for you.
http://www.wardspartswerks.com/
I plan on ordering both parts from this guy soon before the scorching Texas heat is in full effect
Good luck finding what you want!
Scott
2013 RGU Vivid Black. Madstad, long stemmed black mirrors, BRIGHT ASS LIGHT on the rear, Sirius dock, De-cat Header, Jackpot Slash-Up Mufflers (BLACK), Fuel Moto Micro Tuner, Custom Dynamics LED turns, and Attitude adjusted with Mean Mug! Slowly but surely turning all the shiny bits BLACK!
skototrot19 is offline
post #3 of 17 (permalink) Old 04-15-2013, 02:59 PM Thread Starter
Q-Hog's Avatar
Thx for the info. Do you have a set? If so, does the fan turn on automatically when a certain temperature is reached or is it manual?
Q-Hog is offline
post #4 of 17 (permalink) Old 04-15-2013, 03:16 PM
I'm ordering first of the month, but done some research/reading and talked to Jason who owns the place. Fans cut on automatically when rear cylinder temp hits 250 or when you slow to 45 mph or under.
The low temp thermostats he sells just keep the oil from getting too hot before the cooler has to try and cool it down.
Interesting read on his theories and testing on his site if you have a few minutes
post #5 of 17 (permalink) Old 04-15-2013, 03:29 PM
OldNerdGuy's Avatar
I have the Jagg 10 row with fan. I never really took any before/after temp readings, but at least I know the oil is hot whenever I hear the fan running.
OldNerdGuy is offline
post #6 of 17 (permalink) Old 04-15-2013, 03:30 PM
Zog
Zog's Avatar
I have 3 computer style cooling fans behind my oil cooler, not automatic though they are wired to my ACC switch and I turn it on/off.
can find them on ebay for like 70 bucks.
(not my bike in picture actually used the pic from a current ebay auction)
2009 Black pearl 110ci,D&D exhaust, titanium gauges, Bright ass lights tailight, madstad windshiled, jac-knife highway pegs, progressive monotones, Ness Deep Cut Hot Legs etc..etc..etc...
Zog is offline
post #7 of 17 (permalink) Old 04-15-2013, 03:36 PM Thread Starter
Q-Hog's Avatar
Skototrot19, I read the story/theory.. Very in depth.
Zog, great idea.. That's something to consider.
OldN, how you liking your Jag?
Q-Hog is offline
post #8 of 17 (permalink) Old 04-15-2013, 03:50 PM
Oil Cooler/Fans!!!
Have used well over 10yrs ago, no fans though (thought they were all for metrics with rad), seems they'd just blow the heat around, air cooled motor, keep it the wind, they only get so hot. Seen on TV HD runs them in desert heat partialy enclosed. The surface area,passages and fins for oil to even out. 3-400$ can buy shade for you and yours own longevity.
reds4 is offline
post #9 of 17 (permalink) Old 04-15-2013, 04:06 PM
SpringerTodd's Avatar
I have the Wards fans and with these fans, 95 degrees stop and go traffic last summer and no ETIMS on my 09
And it used to cut off rear cyl in 80 degree stop and go before fans.
Oh and by the way I don't have an oil cooler at all on my bike at this time.
Also just to make another point of how little power they consume I left my fans on one time in the parking garage for 12 hours and I still had no trouble starting my bike after my work shift.
They definitely get my vote is the first thing to do for heat issues.
About the only negative thing that occurs is it it blows the heat through the cylinder heads and over on to your right thigh.
-ST
Originally Posted by skototrot19 View Post
Q,
Scott
Sent from Motorcycle.com App
Thank a Vet for your freedom!
God Bless America!!
2009 FLTRI Dark Blue Pearl "Stormy"Zippers Performance 107" Sport Build, Bub 7: 2 into 1, RSD Turbine, TMax 125/125, 2002 FXSTSI "Justine" Springer Custom, lots of goodies.
SpringerTodd is offline
post #10 of 17 (permalink) Old 04-15-2013, 04:46 PM
I have the Wards fans, and an Ultra Cool oil filter, both work, and together they really help.
Oil Bud Oil Cooler easybiker Engine Related 10 07-22-2015 02:34 PM
Oil cooler fans Loner Engine Related 8 12-12-2014 09:44 PM
Oil Bud Oil Cooler install 2013 RG ultra Big_Mo Aftermarket Accessories 0 08-09-2014 10:32 AM
Removing oil filter with oil cooler 02heritage *General Road Glide Discussions/Pictures 17 05-12-2014 12:10 AM
Jagg Oil Cooler turned to Oil Drooler! OldNerdGuy *General Road Glide Discussions/Pictures 6 07-22-2013 12:04 PM
