Checking cam chain tensioners - Road Glide Forums
post #1 of 2 (permalink) Old 04-18-2013, 07:19 PM Thread Starter
groupw's Avatar
........ ran into this site that gives a great walk thru of the process needed to check the cam chain tensioners.
http://www.harleydavidsontensioners.com/
just FYI
'05 FLTRI, King Tour Pak, Vented Lowers, SG fender Fascia
'16 SERGU
groupw is offline
post #2 of 2 (permalink) Old 04-18-2013, 08:05 PM
prodrag1320
Guest
Posts: n/a
inpecting the face (wear surface)of the tensioners is just as important as the depth of wear.the tensioners have a habit of pitting,and the material that comes from the pits will start scoaring your pump & cam plate almost from day one.we`ve seen damage on motors with less than 15K.on 99-06 models,do yourself and pop for a gear drive of the hyd tensioner upgrade
Cam Chain tensioners justincollins Engine Related 16 04-09-2014 10:36 AM
TC 88 Cam chain tensioners after 12,300 miles prince *General Road Glide Discussions/Pictures 5 03-19-2012 10:32 AM
Cam chain tensioners hotrodad Troubleshooting for Road Glides 10 02-09-2011 02:03 PM
Cam Chain Tensioners Ranger58 Troubleshooting for Road Glides 12 09-10-2010 11:03 PM
