Intake manifold leak - Road Glide Forums
post #1 of 7 (permalink) Old 04-22-2013, 01:37 AM Thread Starter
SMOKENJOE's Avatar
What is the best way to check on an intake manifold leak on a 2010 96ci
SMOKENJOE is offline
post #2 of 7 (permalink) Old 04-22-2013, 02:45 AM
Bubba's Avatar
My old tried and true method has always been a little shot of starting fluid with the straw on it, with the motor at idle just a small squirt in the suspected area. If you get an idle up there's a leak.
Bubba is offline
post #3 of 7 (permalink) Old 04-22-2013, 08:51 AM
mocotom's Avatar
I use the same procedure with motor warm and stable at idle, but with WD-40. It will slow the motor instead of speeding it up like the starter fluid does. Spray directly at the top of each intake flange from the left side of the bike.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #4 of 7 (permalink) Old 04-22-2013, 11:36 AM
Both of the mention method work fine. What makes you think that the bike has a intake leak on the Throttle Body? To make sure you can remove and inspect the gaskets on the TB, it doesn't take long to remove the TB and put it back on. Where the TB attaches to the cylinder heads there is a rubber o-ring that is tapered and if the TB was removed before the o-rings may have been put on backwards which may create a poor seal, also when putting on the TB the o-ring may slip out of position which would cause a intake leak. HD wants the o-rings replaced whenever the TB is removed but I have used the same o-rings without a problem. There is also a vacum stem coming out of the top of the TB and it should have a rubber plug on it.
post #5 of 7 (permalink) Old 04-22-2013, 11:45 AM
Wink
bike runnin n the garage door open, perfer the smoke method, environmently friendly, Earth Day
reds4 is offline
post #6 of 7 (permalink) Old 04-22-2013, 12:14 PM Thread Starter
SMOKENJOE's Avatar
Heads
I had the heads of and replaced with S&S heads super stock I dont think they were decked the rubber o rings did not match the stock ones so I used the old ones
post #7 of 7 (permalink) Old 04-23-2013, 10:27 PM
rageglide's Avatar
What O-rings? The intake rubbers? I reuse them often and put a light coat of silicone grease on them to insure they don't hang up.
The intake manifolds have quite a bit of compliance in them and can handle at least .065" change from stock. (.050 mill and a .030" headgasket (-.015"))
Reminds of me trying to use milled heads with an older RamJett intake (no o rings) many years ago... pain in the ass to get that sized, but worked awesome. Of course that was when 90+hp evo's weren't common...
2012 fltrx
rageglide is offline
Oil Leak? Primary Leak? shutzund Troubleshooting for Road Glides 4 06-04-2013 08:55 PM
Intake Breather Leak yourmove Intake and Exhaust 4 07-28-2012 12:21 PM
Intake leak Misplaced Intake and Exhaust 0 07-28-2012 10:40 AM
FS Woods Rebel 43.5 carb, manifold and air cleaner pigfixer Classifieds Archive (3 months old+) 1 11-03-2011 06:49 PM
