Oil Pressure - Road Glide Forums
post #1 of 5 (permalink) Old 04-26-2013, 01:45 PM Thread Starter
rdrnr03's Avatar
Oil Pressure
I am wondering what everyone's pressure is when their bike is hot. Mine at idle seems really low about 5 psi. Is this normal and something I should worry about. Oil level is fine too.
rdrnr03 is offline
post #2 of 5 (permalink) Old 04-26-2013, 01:49 PM
tdkkart's Avatar
Perfectly normal, if your idle is set below 1000rpm you may even get a flickering oil light once in awhile. As long as it runs up in the 30+ range at highway speeds you're fine.
The Softails and Dynas have alot fewer oil pressure complaints, because they don't have a guage................
tdkkart is offline
post #3 of 5 (permalink) Old 04-26-2013, 01:55 PM
can't tell what yr your ride is, but 5-7 at idle is normal if you don't have a highflow oil pump. Which runs @26 idle & 60 at a gallup
reds4 is offline
post #4 of 5 (permalink) Old 04-26-2013, 02:25 PM Thread Starter
rdrnr03's Avatar
I have a 09. I do not get a oil light. And you are right my dyna did not have one so I never worried about it.
rdrnr03 is offline
post #5 of 5 (permalink) Old 04-26-2013, 02:54 PM
faststan's Avatar
My oil pressure runs about 15 at hot idle. 34 at speed. I had a new oil pump put in when I did the cams.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
use of a oil pressure gauge for air psi??? bigeyed76 Equipment-RG 9 03-11-2012 11:31 PM
oil pressure question dennisnyhc *General Road Glide Discussions/Pictures 5 03-18-2011 09:00 AM
Oil Pressure dhhen Troubleshooting for Road Glides 11 12-07-2010 11:50 PM
Oil pressure gauge 2010fltrx Troubleshooting for Road Glides 1 08-16-2010 04:09 PM
