Ported heads - Road Glide Forums
post #1 of 20 (permalink) Old 04-27-2013, 10:04 AM Thread Starter
pat123's Avatar
Ported heads
I'm about to send my heads out to get ported. I've done a bunch of research but I still don't know where to send them. I don't want to spend over 900-1K.
Where would you guys recommend?
I was looking at
Fuelmoto
Bigboyz
Vee twin
where else?
I'm looking for the best bang for the buck. I don't want to spend money that I don't need to. This is on a 13 RG with Powervision,V&H propipe,Woods 555 cams.
Thanks in advance
pat123 is offline
post #2 of 20 (permalink) Old 04-27-2013, 10:12 AM
tsmartt's Avatar
Not sure about the money, but sure about the performance and service at TMan Performance. They are known for the performance work, especially with their heads. Check them out here: http://tmanperformance.com/. I am also running their 555TQ cams and they are awesome.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #3 of 20 (permalink) Old 04-27-2013, 10:42 AM
tdkkart's Avatar
Word of advice, don't pick one set of head over another just because one says "CNC" and costs twice as much.
Head porting is all about getting the proper size, shape and finish in the right places. The trick is in getting the right port and being able to repeat it. You can get an awesome porting job by hand, it just takes longer and is hard to get it the same time after time. Repeatability is where the advantage is in CNC porting. A piss-poor port is a piss-poor port no matter what was used to cut it.
This is not to say there are not CNC heads that are not WELL worth the money, there are, but they're just as hard to find as the really good hand ported heads.
Do some poking around and reading, you'll find some that consistently float to the top.
tdkkart is offline
post #4 of 20 (permalink) Old 04-27-2013, 11:15 AM
Branch/Okeef
Whitehairedpete is offline
post #5 of 20 (permalink) Old 04-27-2013, 11:23 AM
SMOKENJOE's Avatar
S&S Heads
I bought this and it was quick and easy and for the price I still kept my stock heads
S&S Cycle Super Stock Cylinder Heads for Twin Cam - 79cc - Black 106-3233
by S&S Cycle
List Price: $1,298.95
Price: $963.16
Product Description
High port flow gives great performance now, and more later when additional upgrades are done
Heads are fully assembled with springs and valves, and are available in silver or black powder-coat finish to match OEM components
Compression ratios vary depending on cylinder heads chosen, pistons used and engine displacement
79cc heads work great with stock motors for 88 to 103 motors
79cc have 1.940 intake and 1.575 exhaust valve and springs for up to .640 lift
79cc heads accept OEM rocker boxes
Heads are machined for compression releases (sold separately); S&S rocker boxes required when using S&S compression releases
Do not include rocker arm components, intake manifold, gaskets or headbolts (requires eight long OEM length head bolts)
Accept OEM intake manifolds
Made in the U.S.A.
Or larger
S&S Cycle Super Stock Cylinder Heads for Twin Cam - 89cc - Black 106-3240
S&S 106 inch Big Bore Black Kit for 2007-2011 Harley Davidson Big Twin
$652.46
S&S Cycle Super Stock Cylinder Heads for Twin Cam - 89cc - Black 90-1106
$978.59
S&S Cycle Super Stock Cylinder Heads for Twin Cam - 79cc - Black 90-1293
$978.59
Product Description
89cc heads work best for motors over 103in or with high-compression pop-up pistons
89cc have 2.000 intake and 1.605 exhaust and .640 springs
89cc heads accept S&S rocker boxes only (PART #90-4110)
Made in the U.S.A.
JazMan likes this.
SMOKENJOE is offline
post #6 of 20 (permalink) Old 04-27-2013, 11:48 AM
Puff-N-Stuff's Avatar
Branch O'Keefe is considered one of the best. They've done 3 motorcycles for me and I've been beyond happy with the results.
http://www.branchokeefe.com/
Puff-N-Stuff is offline
post #7 of 20 (permalink) Old 04-27-2013, 12:14 PM
Don't waste your money JMO!!! The torque gain for the money is is not a good trade off. I did a 103 Stage IV on my bike with high compression pistons and heads that were ported and polished and the SE 259E cam 58mm Throttle body and 5.3 grams per second injectors and my bike didn't put out any more torque then my 103 with the SE255 cam with stock heads. The only thing I got out of the deal was less mpg and a bike that is not as good of a cruising touring model HD because I had to keep the bike in a higher rpm power band range.
Do a search on the forum and you will find 103 engines with a good low end torque cam putting out 105 lbs or more of torque and the 103 stage IV builds just doing 110 to 115 lbs of torque, not a big bang for the bucks.
post #8 of 20 (permalink) Old 04-27-2013, 02:19 PM
rageglide's Avatar
Ironmark you are comparing SE heads to properly flowed heads. It's not a fair comparison. With your 259 cam and the big bathtub heads the gains are all up in the high RPM range vs low/mid. IMO you can't compare SE "Stage IV" to a real stage IV...
Properly flowed heads bring gains across the board when paired with the right cams AND won't trash the low/mid.
My 95" gave up no power off idle and big gains clear out to redline. Mileage was better than my stock 103. Mileage was even better when I dumped the EFI and installed a carb (close to 50 on the road).
Be realistic and honest as to how you ride and listen to the recommendations of the guy doing the port work. Success depends on properly matched components.
If you never spin the motor over 3500 rpm skip the heads and go with a simple bolt in cam and save money for beer.
2012 fltrx
rageglide is offline
post #9 of 20 (permalink) Old 04-27-2013, 09:15 PM
torqu's Avatar
I would stay with who ever you buy the cam from. Dragos likes Tman cams and probably ports to those flow numbers. Fuel moto if u like the woods cam. Or Tman himself. I myself would go with a tman 555tq, 555C, or a 600sm if your doing heads. Dragos or Tman are your best bet. Proven time and time again. Take your time and call these guys.
torqu is offline
post #10 of 20 (permalink) Old 04-27-2013, 09:25 PM
connector's Avatar
Agree here apples to apples . That been said T-Man and Dragos will both give some great advice and they are the experts. Do some reading and listen to what others have done and how it worked out . SE is bargain basement if you qaulity do some searches, there is some great products avaliable.
09 FLTR 103 Stage III
connector is offline
2012 ported & polished heads/throttle body, pistons and cams 2 bike Mike Parts for Sale 1 02-16-2014 11:19 AM
Dragos ported heads tman 555 stock SCS-4 pipe DragoBikeWorks Dyno Results 7 10-30-2013 08:55 PM
Ported Heads? Fire-Medic Engine Related 27 05-19-2012 10:59 PM
SE HTCC CNC ported heads in silver, $525 68 EB Classifieds Archive (3 months old+) 1 03-22-2012 04:24 PM
