Please help!!! - Road Glide Forums
post #1 of 10 (permalink) Old 04-27-2013, 08:41 PM Thread Starter
Please help!!!
So my 2011 fltrx just started running rough. It misses occasionally and has died twice on me when I came to a stop. I have stage 1 flash , pro pipe and air cleaner. Has run great til now. Any suggestions???
Blackout27 is offline
post #2 of 10 (permalink) Old 04-27-2013, 08:56 PM
faststan's Avatar
Have you or anybody else done any mods lately? How many miles? Have you changed the fuel filter? Have you changed plugs? One tank of gas or several tanks of gas?
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 10 (permalink) Old 04-27-2013, 09:02 PM Thread Starter
I recently put in speakers but nothing to the motor or anything. This is the second tank of gas it has done it on and getting worse. No on the fuel filter. I'm at 13,000 miles on it. Plugs look good but it does run hot
post #4 of 10 (permalink) Old 04-27-2013, 10:37 PM
Triplej's Avatar
Check to see if you have any DTC's.
https://www.roadglide.org/showthread.php?t=4439
Triplej is offline
post #5 of 10 (permalink) Old 04-28-2013, 11:03 AM
FrankieB's Avatar
Check the IAC port inside your throttle body, it could be gummed up or not cycling properly.
06 RK
11 RGU
FrankieB is offline
post #6 of 10 (permalink) Old 04-29-2013, 08:30 AM Thread Starter
I checkedd the DTCs and this is what it told me. PN 32836-09a and PN 34463-11a. read one was an abs thing, whats the other?
post #7 of 10 (permalink) Old 04-29-2013, 10:09 AM Thread Starter
If I was having issues with the tbw would it throw any codes? Due to my time frame before a long trip I would like to cover all basis of getting this fixed. Hate the shotgun method.
post #8 of 10 (permalink) Old 04-29-2013, 12:05 PM
FLTR2008Trike's Avatar
If your doing the Diagnostic correctly through your speedo you will get "B" codes "P" codes and "U" codes
If its engine related it should be a "P" code
Switch and sensors problems are "B" codes
ECM problems are "U" codes
You can get a app for a smart phone is available from Google
https://play.google.com/store/apps/d...Roadside&hl=en
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #9 of 10 (permalink) Old 04-29-2013, 06:23 PM Thread Starter
No trouble codes when testing. Guess ill just have to take it to harley shop. Friend says it sounds like a fuel problem
post #10 of 10 (permalink) Old 05-02-2013, 12:42 PM Thread Starter
crank position sensor was taking a dive. all fixed now.
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 10:51 AM
Thinking about buying a Road Glide,please help. Bruno3290 New Members Welcome Area 16 02-12-2011 12:42 PM
Help me understand EFI & Mapping Please G ECM/Fuel Management systems 7 02-11-2011 11:48 PM
Please help with HD windshield trim piece clloyd *General Road Glide Discussions/Pictures 18 12-16-2010 04:22 PM
Ignition install please help!! raven006 Do-IT-Yourself 4 03-15-2010 03:47 PM
