Milwaukee 8 oil pump - Page 2 - Road Glide Forums
post #11 of 12 (permalink) Old 08-07-2019, 10:58 AM
duglauraflht's Avatar
Lightbulb
Originally Posted by ssmarkom3 View Post
Has anyone had problems with oil pump. My Street glide special with stage 3 oil pump failed causing rear piston to nearly seize.
Dealer ordered both pistons, one jug, new pump and a few other parts. 1200 miles on the bike.
First post needs a hearty welcome...Hearty Welcome from Penciltucky! Ride safe, but just ride!
duglauraflht is offline
post #12 of 12 (permalink) Old 08-07-2019, 11:13 AM
Little Wing's Avatar
Originally Posted by Karnevil View Post
Sorry if to resurect an old post but I am looking at buying my first RG and possibly M8. So one stated the oil pump was a problem when you do stage 3 or 4. so if I just leave it alone or stage 1 or 2 It "should be ok?"I do realize stage 1 has nothing internally changed. Stage 2 is a cam swap, then I should chnage the Pump siince it has to come out anyway, right? Thank you for your insight.
i've been getting a ticking sound on cold startup on my '18 with 15K miles.
talked to the dealer, the service writer asked what kind of oil filter i was using. i told him i bought it there.
the tech said "don't worry about it, and don't believe everything you hear from non-harley sources."
so i'm gonna not worry about it until i'm out somewhere in the middle of nowhere and the valve train locks up
then, they will definitely get an earful!
seriously, if you're gonna change the cam, you might as well spend the $800+ to upgrade the pump, cam plate, lifters, etc.
and check the run-out, too
Little Wing is offline
Feuling oil pump milwaukee 8 THEMASTERDESTROYER Engine Related 0 11-01-2017 08:21 AM
Fueling Oil Pump for 07 and newer mikespeedshop Engine Related 10 06-25-2012 06:09 AM
feuling cam plate and oil pump 07-11 T/C digga25 Classifieds Archive (3 months old+) 0 05-11-2012 09:01 PM
feuling race series oil pump digga25 Classifieds Archive (3 months old+) 0 03-30-2012 06:31 AM
stock oil pump 09 cvo 110 digga25 Classifieds Archive (3 months old+) 0 03-30-2012 06:13 AM
