Milwaukee 8 oil pump - Road Glide Forums
post #1 of 12 (permalink) Old 10-29-2017, 01:46 PM Thread Starter
Has anyone had problems with oil pump. My Street glide special with stage 3 oil pump failed causing rear piston to nearly seize.
Dealer ordered both pistons, one jug, new pump and a few other parts. 1200 miles on the bike.
ssmarkom3 is offline
post #2 of 12 (permalink) Old 10-29-2017, 02:06 PM
Thermodyne's Avatar
Its an issue. The MoCo has upgraded the pumps at least twice now. And of late they are condemning whole engines for reasons as yet not known.
Make sure your dealer measures the runout on the pinion shaft.
Thermodyne is offline
post #3 of 12 (permalink) Old 10-29-2017, 02:55 PM
madmat's Avatar
Sorry to here, keep us in the loop on the repairs. A known issue, lots of talk on the other forum.
18 RGS Bonneville Salt Pearl
madmat is offline
post #4 of 12 (permalink) Old 10-29-2017, 03:49 PM
geo8866's Avatar
I believe it is only an issue for stage 3 and 4. Good luck
geo8866 is offline
post #5 of 12 (permalink) Old 10-29-2017, 06:36 PM
My understanding 2018 has a different pump than 17s. I just had my cam swapped and my builder recommended getting the newest pump. He said HD is on the 4 version of the pump
Lima14 is offline
post #6 of 12 (permalink) Old 10-29-2017, 06:53 PM
canderso1970's Avatar
Shouldn't that be a warranty issue then? Was he recommending the newer oil pump as an upgrade to your system or offering to replace a potentially bad pump or one prone to early failure? Or was he suggesting they would upgrade the oil pump at their cost while doing the work as a preventative warranty measure? (I guess my thoughts are moot if your builder is an Indy.)
-c
2016 Road Glide Special - Velocity Red
1976 Ironhead Hardtail Bobber - Citron Mist Metallic, Hand built by me
canderso1970 is offline
post #7 of 12 (permalink) Old 10-29-2017, 07:02 PM
-c[/QUOTE]
He recommended I get the newer one as a preventative measure. He said I could either go to HD and have them take the bike in and replace it for free but have the time down or buy the parts and he since it wouldn't add time to the build have him install it. I opted the latter as I was anxious for more power
Lima14 is offline
post #8 of 12 (permalink) Old 08-07-2019, 09:08 AM
Sorry if to resurect an old post but I am looking at buying my first RG and possibly M8. So one stated the oil pump was a problem when you do stage 3 or 4. so if I just leave it alone or stage 1 or 2 It "should be ok?"I do realize stage 1 has nothing internally changed. Stage 2 is a cam swap, then I should chnage the Pump siince it has to come out anyway, right? Thank you for your insight.
Karnevil is online now
post #9 of 12 (permalink) Old 08-07-2019, 09:19 AM
RFG7680's Avatar
Depends on the year I think. I have a 19 with the 114 and supposedly the issue is fixed. New pump and plate. But if it's apart then yes. If it was an older version of the oil pump. I would replace it.
RFG7680 is offline
post #10 of 12 (permalink) Old 08-07-2019, 09:48 AM
great for the new bikes. I am looking into either the 15-16 twin cam or maybe a 17 with the M8. First years of motors worry me. that's why I didn't buy a new one then.
Feuling oil pump milwaukee 8 THEMASTERDESTROYER Engine Related 0 11-01-2017 08:21 AM
Fueling Oil Pump for 07 and newer mikespeedshop Engine Related 10 06-25-2012 06:09 AM
feuling cam plate and oil pump 07-11 T/C digga25 Classifieds Archive (3 months old+) 0 05-11-2012 09:01 PM
feuling race series oil pump digga25 Classifieds Archive (3 months old+) 0 03-30-2012 06:31 AM
stock oil pump 09 cvo 110 digga25 Classifieds Archive (3 months old+) 0 03-30-2012 06:13 AM
