Which Front motor mount for a RG 96" ? - Road Glide Forums
post #1 of 10 (permalink) Old 10-30-2017, 12:57 PM Thread Starter
MR. LEE's Avatar
I have a Road Glide 96" 2007 .
The bike rides perfect when it's on the road without any vibrations ,
but as soon as the engine is at idle speed , it shakes like hell
I've replaced the stock front motor mount ( OEM partnr 16207-79D ) , but this mount is exactly the same type of which came out ( brend : Lord J-21920 made in china )
Now i tend to install an aftermarket motor mount , but which is the very best ?
....Velva Ride , Alloy Art , Pro Glide , Paughco , Drag Specialties ????
I want to get rid of that silly idle shakings , I feel ashame on it
MR. LEE is offline
post #2 of 10 (permalink) Old 10-30-2017, 01:03 PM
It is a Harley you know !
post #3 of 10 (permalink) Old 10-30-2017, 01:37 PM Thread Starter
MR. LEE's Avatar
...sure ! , but its far too excessive
MR. LEE is offline
post #4 of 10 (permalink) Old 10-31-2017, 11:09 PM Thread Starter
MR. LEE's Avatar
yesterday , I went to a local harley-workshop , which had the Pro-Glide montor mount on the shelf , so I could inspect that part myself in my hands, to see if it maybe could solve my problem.
Well , that Glide-Pro mount will probably solve ANY FEELING of vibration , because it is almost softer than a marshmallow,
but it won't fix my problem of that excessive wiggling/shaking engine during idle rpm.
So my decision for now is, to stick to the original OEM "D-type" mount , which is more solid and stiffer compared to the jelly poly-urethane aftermarket motor mounts.
MR. LEE is offline
post #5 of 10 (permalink) Old 11-01-2017, 11:35 AM
Woodman's Avatar
On my road king I installed a Glide Pro mount and it settled down the excessive vibration.
Woodman is offline
post #6 of 10 (permalink) Old 11-01-2017, 12:35 PM
Thermodyne's Avatar
I've tried a couple of different mounts on my FXR's and in the end I've found the -d mount to be the most desirable.
With that said, Evo's usually don't vibrate that bad at idle. Are you sure that something else isn't going on with the motor?
Thermodyne is offline
post #7 of 10 (permalink) Old 11-01-2017, 03:27 PM Thread Starter
MR. LEE's Avatar
an excessive shaking engine ,....and ..... vibration..... are two seperate things .
I think the engine should be oke , the dyno-run printout tells it delivers 90 HP
Next time I will measure te compression
MR. LEE is offline
post #8 of 10 (permalink) Old 11-01-2017, 06:40 PM
Thermodyne's Avatar
90 HP tells the tail. It's bigger than stock and prolly has a long duration cam in it. Your trying to domesticate a wild thing.
post #9 of 10 (permalink) Old 11-02-2017, 12:57 AM Thread Starter
MR. LEE's Avatar
mmmmm ,....you could be right about that ,
.....in comparison with the other bikes ( even some newer types ) of my club-members , I'm the winner when it comes to acceleration .
Well ,anyway , I won't give up for now .
Maybe a motor mount with a little bit firmer rubber-compound ( like the cheap made-in-taiwan Drag Specialties ) will give a solution/compromise.
For that 20 euros , it's worth a try
MR. LEE is offline
post #10 of 10 (permalink) Old 11-02-2017, 01:02 AM Thread Starter
MR. LEE's Avatar
I've bought the second hand bike as it is ,.....maybe the previous owner installed an other type camshaft in it.
I don't know what's in it
MR. LEE is offline
2007 RG front motor mount [email protected] Engine Related 4 01-08-2016 11:08 AM
96" motor Wood TW-222 cams fuelmoto Dyno Results 3 11-08-2012 08:45 PM
96" motor and SE slip ons? Effenglide Intake and Exhaust 0 03-14-2011 08:45 PM
porting heads on a stock 96"motor. gabbyduffy Engine Related 3 12-12-2010 07:39 AM
