Check engine light - Road Glide Forums
  • 1 Post By VikingRider
post #1 of 3 (permalink) Old 11-25-2017, 09:48 PM Thread Starter
Check engine light
Just had my sound system upgraded, and noticed that the check engine light is on. I'm hoping that because everything was disconnected, that's the reason for the light being on. I'm taking the bike in to get checked this week. Any thoughts?
08poglide is offline
post #2 of 3 (permalink) Old 11-26-2017, 09:44 AM
Your bike may have thrown a DTC when you were working on it. Go to the troubleshooting section and read on how to access and clear the DTC's. If there is a DTC clear it and all should be good.
post #3 of 3 (permalink) Old 11-26-2017, 11:15 AM
VikingRider's Avatar
What Ironmark said!
BTW I reckon you have the 08-model. I have the 2001 SERG and I always get a «check engine light» that stays on if I have disconnected the battery. I then run the process to read the code and then reset (P,S,SP,t)and you also get the part#. Don't clear any codes if you're not sure how to read them!
There is a difference between Rushmore and pre-Rushmore on DTC-access view, obviously!
ironmark likes this.
FLTRSEI2
VikingRider is offline
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 03:59 PM
Check Engine Light Ran8175 Troubleshooting for Road Glides 0 07-17-2011 01:17 PM
05 Roadglide check engine light camperfan Troubleshooting for Road Glides 8 05-03-2011 07:36 AM
Engine check light keeps coming on 2011 RGC madmatt Road Glide Specific Discussions 11 02-13-2011 11:14 PM
Oil Overfill and Check Engine light Biker Tom Troubleshooting for Road Glides 5 09-15-2010 07:01 AM
