Wanting a better (louder) sound - Road Glide Forums
post #1 of 13 (permalink) Old 05-05-2013, 02:42 PM Thread Starter
getrdone's Avatar
What is this cheapest best option to get a better sound out of my 2012 RGU.
Its all stock except for a set of Rinehart slip-ons. I eventually want to upgrade to a stage II set up but until I save some $$$ Id like to get a little louder deep sound. Any suggestions??? Thanks in advance.
Life is good but God is Great!
getrdone is offline
post #2 of 13 (permalink) Old 05-05-2013, 03:02 PM
Gray Beard
lundboy1's Avatar
Cut the cat out of the stock head pipe do a quick thread search ... It'll put more rumble in the pipes
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #3 of 13 (permalink) Old 05-05-2013, 03:31 PM
skratch's Avatar
yep, get rid of the cat and it'll sound much better
skratch is offline
post #4 of 13 (permalink) Old 05-05-2013, 04:13 PM
+1
I had the Rhinehart 4" slip ons only on my 2013 RGU and had the same feeling. Only thing is, if you remove the Cat, you gotta do a tune. There are many opinions on this. I just went stage 1, and added the V&H dresser dual head pipes, SE air cleaner and SE super tuner with a dyno tune. Sounds good to me now. I just live the true dual tone at idle.
FLhogger is offline
post #5 of 13 (permalink) Old 05-05-2013, 07:21 PM Thread Starter
getrdone's Avatar
Let me rephase my question
I have $1,500. to spend. What can I get with that to start, True duals? Heavy breather? Tuner?
getrdone is offline
post #6 of 13 (permalink) Old 05-05-2013, 07:37 PM
Bandit's Avatar
I think all of the above if you do your research.
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
post #7 of 13 (permalink) Old 05-06-2013, 12:29 AM
Taccone's Avatar
Depending on what exhaust you go with, you may have a bit cash left over for cam's. That will def. make the motor sound completely different when idling and runnnig.
Taccone is offline
post #8 of 13 (permalink) Old 05-06-2013, 01:17 AM
I paid 2k for the V&H dresser duals, SE air cleaner, and SE super tuner. Including the install and dyno session. This was all done at the dealer, so I am sure it could be done within your budget with a little bit of shopping.
FLhogger is offline
post #9 of 13 (permalink) Old 05-06-2013, 10:13 AM
tsmartt's Avatar
I went with Drago Bike Works Dragula 2:1, TMax tuner and Zipper's Max flow breather for your budget. Call Frank and he will give you a great deal and offers the best service you will get in the motorcycle industry. He is a forum sponsor and gives discounts. You will not be disappointed in the sound or performance. When your budget gets a little bigger, add cams and you will have a new bike! Good luck.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #10 of 13 (permalink) Old 05-06-2013, 06:22 PM Thread Starter
getrdone's Avatar
Who is Frank and where is he located?
getrdone is offline
Better sound quality houston Audio 3 03-16-2014 08:44 PM
Cut baffles shorter to produce louder sound? ScreamingSkulls Intake and Exhaust 0 09-04-2013 09:13 AM
Wanting a better (louder) sound. getrdone Intake and Exhaust 6 05-11-2013 06:10 PM
dont need louder but want better then stock rob883 Audio 2 02-05-2013 03:57 PM
Deep sound, but not much louder than stock... can it be done? Traveller Intake and Exhaust 27 05-21-2011 11:58 PM
