Andrews 57H - Road Glide Forums
post #1 of 57 (permalink) Old 05-06-2013, 10:40 AM Thread Starter
ShitHouseRat's Avatar
Andrews 57H
The Andrews 57H cams came in today. I have some time this week off from work so I should have them in by week end. Got Fuel Moto rods too and T-168 bearings.
ShitHouseRat is offline
post #2 of 57 (permalink) Old 05-06-2013, 11:26 AM
spokanebagfan's Avatar
Sweet let us know really want to install mine but have to wait for enough time.
spokanebagfan is offline
post #3 of 57 (permalink) Old 05-06-2013, 01:16 PM
X In Black's Avatar
Subscribed. 57H is #1 on my list, too. Looking forward to your opinion of it's performance.
2012 FLTRX
Rinehart 2 Into 1|Ness Big Sucker AC|Andrews 57H Cams|PowerVision
X In Black is offline
post #4 of 57 (permalink) Old 05-06-2013, 10:58 PM
SIG556's Avatar
My Build
2012 RGC:
Dragos Headers and True Duals
Roland Sands Breather
Thundermax
Andrews 57H Cams
Black Ops Lifters
Stock Push Rods
.30 Cometic Head Gasket
30 Tooth Primary Sprocket
It's now feels the way it should.... balls to the walls!
Back In Black!
SIG556 is offline
post #5 of 57 (permalink) Old 05-07-2013, 05:47 PM
sonic_cruzer's Avatar
Be prepaired that you may also need cam-chain tensioners and possibly a calibrated washer.
2008 Vivid Black RG, CB TRSSC, Ohlins #2~#2B on Rear, -1" Progressive Monotubes in forks, RP EMS Tuner, TW-222 cams, Kromewerks Sweeper +2 bars, Rivera Pro VP Clutch, SuperTrapp 2:1 Exhaust, SE Compensator, Medallion Gauges, UltraCool, all lighting is LED including Daymakers.
sonic_cruzer is offline
post #6 of 57 (permalink) Old 05-07-2013, 07:34 PM
Corrupted's Avatar
Just put a set in my buddies 2012 last Sunday, took me around 5 hours with adjustables. Getting it tuned next wendsday, I will post the sheet when its done
You only need to be 10% smarter than the thing your working on!
Corrupted is offline
post #7 of 57 (permalink) Old 05-07-2013, 09:34 PM
cwdouble's Avatar
Subscribed to see how it all works... wanting to cam mine
cwdouble is offline
post #8 of 57 (permalink) Old 05-08-2013, 12:02 AM
subscribed
boston rg is offline
post #9 of 57 (permalink) Old 05-11-2013, 08:26 PM Thread Starter
Had some rainy weather here in Conn so a good time for the swap.
Rolled it in and got started.
post #10 of 57 (permalink) Old 05-11-2013, 08:29 PM Thread Starter
Once it came to cutting the rods it was the point of no return!
No problem, had a nice bolt cutter.
Andrews 57H, now what? LM1976 Engine Related 3 06-23-2014 03:17 PM
Andrews 57H Cams-What pipes are you running? LM1976 Intake and Exhaust 7 05-11-2014 07:00 PM
Andrews 57H Installed PauleyB Engine Related 11 03-31-2014 07:37 PM
2011 FLTRX Andrews 57H vaughtcity Dyno Results 2 11-08-2013 11:24 AM
Andrews 57H cams ShitHouseRat Sold 6 09-11-2013 08:33 PM
