up grade on cams - Road Glide Forums
post #1 of 9 (permalink) Old 05-06-2013, 01:36 PM Thread Starter
up grade on cams
I have a 2012 rg and I am up in the air on cams? I have a big sucker ac, Rinehart 2-1 & PC V. looking at a S&S 551 or Andrews 57H I ride single in the lower rpms 2000-4000 most of the time except when I am running my hard with my buddys. Are most of the bugs out of the chain drive, or is the gear drive the way to go?
craig demel is offline
post #2 of 9 (permalink) Old 05-06-2013, 04:18 PM
prodrag1320
Guest
Posts: n/a
we use alot of the 551`s.i think the S&S .583 might be a better choice if you like to get on it with your buddies from time to time,the 57 would be a good choice too(all three want to be set @ 9.8-1).chain drive would also be fine,no real need for gear drive in the `07 up motors (unless its a very aggressive build with bigger cams)
post #3 of 9 (permalink) Old 05-06-2013, 04:38 PM
Gonekat's Avatar
I have Andrews 48H in my 103. stock heads, Jackpot tuned slipons, catless stock header. Its rips from about 2700 through rev limiter. 98/119 are the numbers. the dyno sheet is posted in that subforum. as if there wasn't enough to think about, these are a good set to consider as well.
2011 RGC, Sedona Orange 103" w/ 48H cams,PM Icon 21" wheel,Kury Mach 2 intake,Jackpot 3.5, PM brake and shift levers, CB 14" TRSSC shield, Sinister 14" apes, custom levers.Black exhaust,floorboards,pegs and crash bar.
Gonekat is offline
post #4 of 9 (permalink) Old 05-06-2013, 04:39 PM
spokanebagfan's Avatar
Price comes into the equation as well. Andrews is quite a bit cheaper
spokanebagfan is offline
post #5 of 9 (permalink) Old 05-06-2013, 04:40 PM Thread Starter
what is a fair price to get a set of cams installed?
post #6 of 9 (permalink) Old 05-06-2013, 05:45 PM
tsmartt's Avatar
My installation for TMan 555TQ, SE adjustable pushrods and bearings was $350 labor at my dealer. Book install calls for 4 1/2 hours. I was quoted $325 by an Indy if I bought all parts from him.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #7 of 9 (permalink) Old 05-06-2013, 07:43 PM
prodrag1320
Guest
Posts: n/a
300-350 on average
post #8 of 9 (permalink) Old 05-06-2013, 10:41 PM
Gonekat's Avatar
Mine were 520 with dyno tune afterwards.
Gonekat is offline
post #9 of 9 (permalink) Old 05-07-2013, 10:35 PM
I took the S&S 583 out of my Ultra Limited and went with the 222 from Woods. Couldn't be happier with the change. Give Bob a call and discuss 'Your' riding style and what you want out of a cam.
george liles is offline
Screamin’ E agle® Pro 103 Performance Up grade Kit 27544-10A joshpyles12 Engine Related 11 05-05-2016 08:03 AM
front end up grade dozer23 Suspensions 17 04-13-2016 08:24 PM
simple up grade Remmag Audio 9 06-22-2015 11:48 PM
Bagger nation Stereo Up Grade Roadglide Mike Audio 6 03-15-2011 06:39 PM
2009 se exhaust up grade jim Intake and Exhaust 1 07-17-2010 12:35 PM
