Hissing type noise in cam chest - Road Glide Forums
post #1 of 6 (permalink) Old 12-13-2017, 05:12 PM Thread Starter
TooTall46's Avatar
Brought 2017 road glide special 107 in for odd noise near cam chest. Sounds almost like a hissing from a possible fluid restriction. Dealer has had it since 30 November and can not figure out problem. MOCO has told them to split the case and spec out the whole bottom end. Anyone else experiencing a odd noise like that when bike is up to temp and idling, bring it in
TooTall46 is offline
post #2 of 6 (permalink) Old 12-13-2017, 05:49 PM
Desertwndrr's Avatar
I haven't heard anything like that. However if my dealer were going to cover the splitting of the case and reassembly, I'd be having the crank beefed up during the process and possibly having the cases machined for larger jugs. Pretty cheap insurance and will give some headroom should you decide to upgrade.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #3 of 6 (permalink) Old 12-13-2017, 06:37 PM
Knew of a bike that hissed, it would stop after it got good and warm. Finally blew a head gasket and after repairs - no hissing noise.
NMRoadrunner is offline
post #4 of 6 (permalink) Old 01-07-2018, 03:43 PM
Here here to the beefed up crank so my 2cents is if the motor was out and open install a Fueling oil HP oil pump and cam chest. Hereís why
I did a 107 build on my 2010 96 ci RG runs awesome did a complete Darkhorse blueprint/balance welded crank HBeam rods 106 hp 117 to. 500 miles and a clatter took it in pulled all the covers push rod dropped
While the covers were off had the Fueling parts above installed AMAZING old idle psi 15 now 35 at speed old 35 psi now 55 psi all day cooler quieter better throttle I do not know why Here If I only had the money for one upgrade it would be The Fueling pack with reaper cams I did Woods 777ís this is the single best upgrade any of us in this community can do.Especially the VTwin crowd.ride
vincem1
scarlet red 2010 RG
vincem1 is offline
post #5 of 6 (permalink) Old 01-07-2018, 03:50 PM
Sounds like an exhaust leak at the front pipe or maybe a compression release is stuck open there automatic inside the rocker box
vincem1
scarlet red 2010 RG
vincem1 is offline
post #6 of 6 (permalink) Old 01-08-2018, 09:27 AM
Sounds like there could be a possibility that the crankcase is not venting properly. The umbrella valves may be malfunctioning.
hissing noise wolfiisjc Troubleshooting for Road Glides 3 08-20-2018 11:38 AM
For Rent = Gary Beatty cam chest tools r0de_runr Do-IT-Yourself 20 02-20-2015 05:51 PM
Hissing noise in motor????? Louster47 *General Road Glide Discussions/Pictures 15 05-11-2013 08:23 AM
Cam chest tools staush Miscellaneous for Sale 0 01-01-2013 06:34 PM
Gloss vs Wrinkle - Primary, cam chest etc...H TXcruiser Paint & Bodywork Section 3 04-03-2012 09:25 PM
