11.25 pistons added what’s the compression? - Road Glide Forums
 14Likes
post #1 of 58 (permalink) Old 12-15-2017, 09:37 PM Thread Starter
2016 RGU wet head bike with stock heads. Adding 11.25 to 1 pistons. Stock C.R. is 10.0-1. Will the C.R. be higher than 11.25-1?
Part number for the pistons is 27000007
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #2 of 58 (permalink) Old 12-16-2017, 09:44 AM
Thermodyne's Avatar
Originally Posted by freedom1974 View Post
2016 RGU wet head bike with stock heads. Adding 10.5 to 1 pistons. Stock C.R. is 10.0-1. Will the C.R. be higher than 10.5-1 ?
What pistons? Were they cut specifically for that head, if so, then 10.5:1. or there abouts
If they were cut for a larger chamber head, it will be more. And visa versa.
You can calculate it. You'll need the bore, the stroke, the chamber volume of the head, and the dome volume of the piston as well as the volume of the head gasket.
Thermodyne is offline
post #3 of 58 (permalink) Old 12-17-2017, 02:30 PM Thread Starter
They are Screaming Eagle 10.5-1 pistons. The bike has the stock wet heads on it and it’s a 103. I am worried about to much compression and blowing head gaskets. The HD dealer told me it will be ok but not sure I trust that statement.
post #4 of 58 (permalink) Old 12-17-2017, 04:17 PM
FDR's RGC's Avatar
In this case dealer is correct.
FDR's RGC is offline
post #5 of 58 (permalink) Old 12-18-2017, 09:26 PM
Desertwndrr's Avatar
Do you know the CC of the piston dome?
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #6 of 58 (permalink) Old 12-18-2017, 10:51 PM Thread Starter
They are the Screaming Eagle 10.5-1 pistons. Where would I get the information?
post #7 of 58 (permalink) Old 12-19-2017, 09:34 AM
Yellow09SERG's Avatar
Do you know what cam is in the bike? Cam timing can add or subtract from that compression
Yellow09SERG is offline
post #8 of 58 (permalink) Old 12-21-2017, 07:13 AM
How does cam timing effect compression? Not messing with you, I really want to know. Thank's
Buzzy is offline
post #9 of 58 (permalink) Old 12-21-2017, 07:35 AM Thread Starter
Screaming Eagle 585
post #10 of 58 (permalink) Old 12-21-2017, 07:36 AM Thread Starter
Intake valve close I think is what affect the compression.
High Compression Pistons for the HD 110 Upgrade kit - input oc357 Engine Related 2 06-17-2016 06:05 AM
High compression pistons chefskeeter Engine Related 18 04-13-2013 07:15 AM
95'' heads high compression pistons and cams OuchMMC Dyno Results 18 04-03-2012 11:14 PM
Veterans Day 11/11/11 PittsDriver *General Road Glide Discussions/Pictures 17 11-11-2011 10:47 AM
