2012 RGU: Coughed, died and now wont turn over - Road Glide Forums
  • 1 Post By MightyWhitey
post #1 of 9 (permalink) Old 12-25-2017, 01:53 PM Thread Starter
2012 RGU with 43,000 miles. Road the day before ~ 100 miles, a few WOT pulls to air it out. Started the next morning, a little chilly (Houston) but not cold, didn't let warm up too much, started to pull out of driveway, it coughed, died. Now sounds like starter is engaging (one clack, not clicking), stressed/power strain, motor doesn't turn over. Will move bike a little if in gear and clutch in. Replaced battery jsut in case. Where should i dig into first?
(222 cams, woods lifters, fuel moto push rods, 2-1-2 header, suppertrapps, VH intake).
vmaxerg is offline
post #2 of 9 (permalink) Old 12-25-2017, 02:05 PM
Little Wing's Avatar
1. pull the plugs
2. see if it will crank over
3. if it cranks over put it in 2nd gear try to push it
imo that's where i would start.
'18 FLTRX • '04 BAR HOPPER • '94 FLSTCTHE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #3 of 9 (permalink) Old 12-25-2017, 02:45 PM
if the engine cranks over with the spark plugs removed, you're prolly home free.
don't force it... if it hasn't already, it could cause a trainwreck in your valvetrain
you could remove the pushrods, then the rocker covers, etc.
don't know your mechanical expertise, so it's hard to guess your ability.
hope it works out for you...
post #4 of 9 (permalink) Old 12-25-2017, 02:53 PM Thread Starter
Thanks for the suggestions, will start there. Fairly mechanically inclined, just haven't dug into a Harley too much...
vmaxerg is offline
post #5 of 9 (permalink) Old 12-25-2017, 07:22 PM
MightyWhitey's Avatar
No different than digging into any other engine. Don’t let it intimidate you. If you have a book for specs and procedures you’re set. If you don’t and don’t want to buy one I’ll try to send you a digital copy or I can snap pictures of pages and text them to you. Message me if you need that.
Punishher7 likes this.
MightyWhitey is offline
post #6 of 9 (permalink) Old 12-25-2017, 07:24 PM
Almost sounds like your compensator took a dump.
post #7 of 9 (permalink) Old 12-26-2017, 05:57 AM
Is the battery dead? Bike won't run with a dead battery. Did you try pulling up DTC codes? If the battery falls below 75% there isn't enough juice in the battery to start the bike. The 2012 models had a recall on the Voltage Regulator so that's would be a good reason to suspect the battery as the problem. The battery may not be bad it may just need charging. Also check your battery connections.
post #8 of 9 (permalink) Old 02-20-2018, 07:19 PM Thread Starter
appears loose sprocket bolt on rear cam allowed it to move inward contacting crank/flywheel
vmaxerg is offline
post #9 of 9 (permalink) Old 02-21-2018, 11:57 PM
UT_Larry's Avatar
I had a backfire on my evo that broke an alignment pin on the cam shaft that messed up the timing.
UT_Larry is offline
Cold Start Issue - Won't turn over below 40 but starts fine when over 40 KRav7 *General Road Glide Discussions/Pictures 11 12-13-2016 11:31 PM
changed handle bars wont start now rob883 Controls & Handlebars 11 05-06-2013 07:57 AM
2012 RGU wont start after cam swap Bluchevypick Troubleshooting for Road Glides 5 04-20-2012 10:35 PM
changed bars now bike wont start NO4NBIKES Controls & Handlebars 4 01-02-2012 10:06 AM
Battery died, now speakers not working!!!!!! schnid72 Audio 11 02-12-2011 07:33 PM
