About to pull the trigger on cams - Road Glide Forums
post #1 of 8 (permalink) Old 05-08-2013, 02:30 AM Thread Starter
cwdouble's Avatar
I am about to pull the trigger on cams. I know I am going to have to get new bearings, seals, and, adjustable pushrods. I have almost 30K miles. Should I also buy new lifters and tensioner? I dont' want to have to get everything put back together and find out i need to get back inside to replace some more stuff.
Any help would be greatly appreciated.
cwdouble is offline
post #2 of 8 (permalink) Old 05-08-2013, 03:46 AM
JacktheBagger's Avatar
probably not on the tensioner , but it's an opportunity to upgrade the lifters to some better items , and you are already there , so go for it
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 8 (permalink) Old 05-08-2013, 04:38 AM Thread Starter
cwdouble's Avatar
JtB can you suggest lifters? I am not edumakated on lifters for the bike... Roller, non roller, hydraulic, solid... Like on cars... I remember putting rollers and roller rockers on my first MoPar
cwdouble is offline
post #4 of 8 (permalink) Old 05-08-2013, 05:40 AM
torqu's Avatar
What year bike? I myself would replace or upgrade the cam plate and tensioners if it was a pre 07
torqu is offline
post #5 of 8 (permalink) Old 05-08-2013, 06:45 AM
93-331-29psi's Avatar
I agree with torqu. Definitely replace the cam plate and tensioners while you're in thereIt's cheap insurance. As far as lifters I'd be replacing them as we'll as there are known issues on some of these bikes (mostly the 110). Good luck.
Sent from Motorcycle.com App
93-331-29psi is offline
post #6 of 8 (permalink) Old 05-08-2013, 07:34 AM
prodrag1320
Guest
Posts: n/a
if its 99-06,go with geardrive cams.if its got the "B" lifters in it,no need to change them (BTW,HD has ran roller lifters just about forever,never had flat tappets like automotive units)
post #7 of 8 (permalink) Old 05-08-2013, 12:19 PM Thread Starter
cwdouble's Avatar
I have a 2011 RGU. Should I still upgrade the cam plate?
cwdouble is offline
post #8 of 8 (permalink) Old 05-08-2013, 04:19 PM
prodrag1320
Guest
Posts: n/a
no reason to on `07 up
Questions about 14'' Santee apes, before I pull the trigger Robgrover Controls & Handlebars 5 04-30-2015 02:10 PM
Ok, I'm ready to pull the trigger for tunes for '13 RGC. GrafixxMan Audio 7 03-26-2014 05:21 AM
Ready to pull the trigger steel breeze *General Road Glide Discussions/Pictures 16 11-10-2013 07:41 PM
Got to pull the trigger on a .50 BaggerBrian General Off-Topic Discussions 15 03-21-2013 02:15 PM
Should I pull the Trigger nightrider069 Engine Related 6 11-04-2012 08:16 PM
