Adj pushrods - Road Glide Forums
post #1 of 4 (permalink) Old 05-08-2013, 02:35 AM Thread Starter
cwdouble's Avatar
Adj pushrods
I am about to pull the trigger on replacing my cams and will be putting in adj pushrods in. My main question is can someone please explain how to correctly install them. I have read about tightening them and then waiting for the lifter to "bleed down". I have never done this so I have no idea what they are talking about. Can someone write this out in layman's terms? if there is not a good write up I will see if i can remember to take pics and document when I do this.
Can someone suggest a good brand for the pushrods or will the SE adjustable pushrods be good. (I am not going to be going to radical with the cams prolly the Tman 555tq).
cwdouble is offline
post #2 of 4 (permalink) Old 05-08-2013, 03:29 AM
Triplej's Avatar
Here is an excellent video tutorial. There are lots if good options for pushrods and certainly SE are in that category.
http://m.youtube.com/watch?v=n5KvamRqCis
Triplej is offline
post #3 of 4 (permalink) Old 05-08-2013, 04:32 AM Thread Starter
cwdouble's Avatar
Thanks triple I will have to watch when I am back in front of the computer.
cwdouble is offline
post #4 of 4 (permalink) Old 05-08-2013, 07:11 AM
Hullhorr's Avatar
You are going to love those cams. I also have the SE adjustable pushrods.
If you are replacing your lifters soak the new ones in your motor oil overnight. Once you have adjusted the SE push rods the 2-1/2 turns the instructions say wait 10-minutes before turning the motor over by hand. This is what they mean by bleed down. It will allow the oil in the lifters to bleed down so it's not putting excess pressure on the rocker arms and valves.
If you replace your lifters the adjustment in the SE instructions might be different depending on the lifter you pick. Gatorman lifters for example require less adjustment than what the SE instructions say. Keep in mind the SE pushrods are 24teeth per inch.
2009 FLTR MOP
Hullhorr is offline
FS SE Pushrods(adj & fixed) akjeff Parts for Sale 3 01-01-2014 09:22 AM
Installing Cams & Adj. Push Rods Q-Hog Engine Related 34 11-04-2012 10:48 PM
Kuryakyn Adj. Passenger Pegs for HD adj. passenger boards txflyer Classifieds Archive (3 months old+) 0 08-18-2012 05:14 PM
Step by step Cam removal/installtion and pushrod adj. Gonekat Do-IT-Yourself 5 12-06-2011 08:30 AM
Great add on, HD Adj. Riders Backrest Hillglide *General Road Glide Discussions/Pictures 0 03-09-2011 06:22 PM
