Oil Cooler Damage - Road Glide Forums
post #1 of 1 (permalink) Old 12-28-2017, 10:46 AM Thread Starter
rider17's Avatar
Oil Cooler Damage
Came out a couple weeks ago and found a small oil stain under my oil cooler on my 17 RGS. Had the dealer pick it up and got the dreaded phone call. It appears that the oil cooler mounted on the front downtimes of the M8 bikes is pretty fragile. I went off of a curb near my driveway because the neighbor was blocking the driveway. Nose first off the curb was enough to bump the bottom of the cooler and push it up less than 1/8" causing the hose between the cooler and the line to become occluded. This caused a backup in oil pressure which blew a seal. Waiting on parts that are backordered. FML.
I've gone off the curb 100s of times on bikes and never had a problem. It appears one should not do so with the M8 bikes.
Anyone know of a relocation kit for the oil cooler? Apparently the dealer has seen several of these from road debris strikes as well.
rider17 is offline
Front fender damage after fork oil change hoosierboarder Suspensions 15 08-01-2015 08:04 AM
Oil Bud Oil Cooler easybiker Engine Related 10 07-22-2015 01:34 PM
Oil Bud Oil Cooler install 2013 RG ultra Big_Mo Aftermarket Accessories 0 08-09-2014 09:32 AM
Removing oil filter with oil cooler 02heritage *General Road Glide Discussions/Pictures 17 05-11-2014 11:10 PM
Jagg Oil Cooler turned to Oil Drooler! OldNerdGuy *General Road Glide Discussions/Pictures 6 07-22-2013 11:04 AM
