Valve train noise - Road Glide Forums
 7Likes
post #1 of 12 (permalink) Old 01-14-2018, 11:00 AM Thread Starter
1st Sgt's Avatar
Valve train noise
I've noticed a temporary valve train noise periodically. After the bike has been sitting (at least over night) when it starts up everything is fine. For the first quarter mile everything is fine but occasionally after that first quarter of a mile I get a pretty significant valve train noise but it seems like if I reve up to about 3500 RPM and let the revs drop back to idle - the noise goes away for the rest of the ride/day. Any thoughts? I'm thinking its time to have the tappets replaced. (2011 RGU, 103, Kuryakyn cams installed at 12000 miles bike currently has 64000 miles)
1st Sgt is offline
post #2 of 12 (permalink) Old 01-14-2018, 11:53 AM
Road dawg's Avatar
Well i can tell you from experience, my lifters failed at 10k on my 2011 FLTRX and that is kind of how it started somewhat, i heard alot of noise on startup after it was hot, and on accel sometimes. I installed S&S premium lifters along with cams and HD quickie pushrods, now runs real good no noises. These years came with the infamous C lifter, they were know for problems, and yes china junk.
1st Sgt likes this.
Road dawg is offline
post #3 of 12 (permalink) Old 01-14-2018, 12:16 PM
lil chief's Avatar
As suggested, I'd probably start with replacing the tappets. Mine were bleeding down and rattling after a few hours of sitting, with only 400 + miles on the bike. Generally thats when the lifters bleed down, is overnight or long periods of sitting, causing the rattle. Valve trains usually get a bit noisier after everything is hot, the oil is thinner, and the expansion/contraction of the metals.
Are you sure it's coming from the valvetrain? Sound travels through these motors and can be difficult to locate, especially when moving.
With that being said, make sure all external stuff is tight, and that the exhaust isn't hitting the frame or elsewhere. Maybe the next time the noise occurs, stop and get off the bike to see if you can pinpoint exactly where it's coming from.
Lil Chief
1st Sgt likes this.
lil chief is offline
post #4 of 12 (permalink) Old 01-14-2018, 12:26 PM
Road dawg's Avatar
If you want you could take a shot and dump some marvel mystery oil in the motor to see if maybe there is a sticky lifter, but if it was me i would switch out the lifters. I am suprised that you didn't put new ones in with the cam swap.
post #5 of 12 (permalink) Old 01-14-2018, 12:59 PM
Thermodyne's Avatar
A light rattle sort of tap is usually the rocker shafts. Usually worse in the 2500-3500 range. Rocker lockers will fix that.
Tappet issues are much louder, and more in time with motor RPMs.
But with the miles you have on those tappets, smart money would be on at least having a look at them.
1st Sgt likes this.
Thermodyne is offline
post #6 of 12 (permalink) Old 01-14-2018, 03:40 PM
a buddy of mine had a similar noises and installed a set of Rocker Lockers i told him about and most of the noise went away. I'm gonna be installing some soon too
post #7 of 12 (permalink) Old 01-14-2018, 03:55 PM
Road dawg's Avatar
Wow really? how much are those rocker lockers and where do ya get em?
post #8 of 12 (permalink) Old 01-14-2018, 04:27 PM
eddienelson's Avatar
http://rockerlockers.com
2016 RG Custom Vivid Black
eddienelson is offline
post #9 of 12 (permalink) Old 01-14-2018, 06:56 PM
Road dawg's Avatar
Originally Posted by eddienelson View Post
Thanks! next on my project list! good info.
eddienelson likes this.
post #10 of 12 (permalink) Old 01-15-2018, 10:11 AM
With the mileage on the bike I would replace the lifters first. Chances are the rear cylinder lifters are going out, in my experience the rear cylinder lifters are the first to go bad. Replace the lifters and see what happens and do it before you get cam damage which could happen if the lifter fails.
1st Sgt, Road dawg and turbochrisb like this.
Compensator or valve train noise???? StGhost Engine Related 19 08-29-2018 09:16 PM
Valve train noise thread sfcusaret2004 Engine Related 12 08-29-2016 04:09 AM
Possible valve train noise rlaf75 Troubleshooting for Road Glides 20 05-24-2016 09:42 PM
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 05:23 AM
Increase in Valve train noise when engine cold StriderJim Troubleshooting for Road Glides 8 10-07-2012 09:21 AM
