Engine noise 96" - Road Glide Forums
post #1 of 4 (permalink) Old 05-13-2013, 05:30 AM Thread Starter
BigB64's Avatar
Engine noise 96"
My bike has load noise from left side. Thought it was engine related but shifter linkage has become loose.
If you dont like what she is saying,Go for a ride
BigB64 is offline
post #2 of 4 (permalink) Old 05-13-2013, 06:20 AM
If suspected from the primary, double-check the compensator nut.
Scott
Hillsidecycle.com is offline
post #3 of 4 (permalink) Old 05-13-2013, 07:59 AM
What year is the bike? Is the noise there all the time? Does it happen at any speed? Any gear? My 09 make noises in 5th gear only but thats a known issue due to the straight cut 5th gear in the trans.
post #4 of 4 (permalink) Old 05-16-2013, 03:44 PM
SMOKENJOE's Avatar
Noise
I have the same noise I think I replaced my heads with S&S super stock 79cc heads no noise replaced stock cam with S&S 570 easy start cams no noise replaced 570 cam with 583 easy start cam have a noise sounds like in the front head valve train?? repalce lifters to fueling lifters and replaced pushrods to S&S quickie pushrods noise still there replaced cam bearings that had 300 miles on them still noise there sounds like a lifter ?? any way gonna ride the hell out of it if it blows I will get a new engine.
SMOKENJOE is offline
95", 96", or 98" Iron1 Engine Related 12 01-14-2017 05:04 AM
Need map for 2010, 96", v&h dresser duals, rush 3.5", 2" baffle ilmanzo31 Map Section 3 07-28-2016 03:52 PM
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
103" engine 'popping' noise? AngrySmurf Troubleshooting for Road Glides 1 03-12-2012 09:43 PM
