Issues after Cam install - Road Glide Forums
post #1 of 19 (permalink) Old 05-13-2013, 07:43 AM Thread Starter
Deadstroke's Avatar
So here is my setup
2013 RG Ultra
Dragos 2 in 1 pipes
Harleys hi-flow air cleaner
Andrews 57H Cams
Setup the cams and got a few base maps from setups and it just bogs out around 2500 a ton of hesitation till about 3200 then it just takes off. Had no issues during the install.
Looking for a good tune for this and any other suggestions.
Tunes I got where from other members of the board and one was someone who that that tune from fuel moto which wasnt for that set of cams but should have been close..
Thanks in advance.
Deadstroke is offline
post #2 of 19 (permalink) Old 05-13-2013, 08:41 AM
ShitHouseRat's Avatar
Once I get a Windows OS for my computer I'll send mine.
During install, did you replace the oil pump seals with new or just reinstall the originals?
ShitHouseRat is offline
post #3 of 19 (permalink) Old 05-13-2013, 08:48 AM Thread Starter
Deadstroke's Avatar
Thanks.. I replaced them..
post #4 of 19 (permalink) Old 05-14-2013, 06:19 AM
verticalrich's Avatar
I have the same cam 57h and after installing cam took out for a ride and bike ran about the same as your describing, but after a couple power vision auto tune sessions on a map I got emailed from dyno jet for my combination it screams from 2500 to 6000. I still am waiting on my dragula but I purchased the auto tune module for the power vision and plan to use both wide and narrow band sensors (auto tune pro) as frank says thats the way to go.
2012 FLTRU SE A/C, Andrews 57h, Dragula 2-1, Khrome Werks street sweeper 2+2, Dyno Jet Power Vision with auto tune pro
verticalrich is offline
post #5 of 19 (permalink) Old 05-14-2013, 06:44 AM
mocotom's Avatar
Deadstroke
What tuner are you using?
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 19 (permalink) Old 05-14-2013, 08:14 AM Thread Starter
Deadstroke's Avatar
Originally Posted by mocotom View Post
Deadstroke
I have the powervision.
post #7 of 19 (permalink) Old 05-14-2013, 08:16 AM Thread Starter
Deadstroke's Avatar
I havent tried the auto tune with the tune I got from dynojet.. What did you do to auto tune it? Just run it a few times then auto tune then run again and auto tune? I have not had any good experience with the auto tune basic on the PV yet
post #8 of 19 (permalink) Old 05-14-2013, 08:53 AM
HellInABucket's Avatar
First, make sure you have all the latest firmware updates on the device. (connect it to your PC with the USB cable, and run the PV Update client)
http://www.youtube.com/watch?v=l1fppB5rSYo
HellInABucket is online now
post #9 of 19 (permalink) Old 05-14-2013, 09:06 AM Thread Starter
Deadstroke's Avatar
Yep did that.. it is 100% up to date
Thanks alot for the Video.. Thats Awesome I can say I was definitely not doing it correctly
post #10 of 19 (permalink) Old 05-14-2013, 10:16 AM Thread Starter
Deadstroke's Avatar
Just thinking about it.. How many times does do you need to do the auto tune? How far should you ride when you do it? Thinking I would auto tune and drive to work..
First Ride after Torque Cam Install paid4c4 *General Road Glide Discussions/Pictures 21 04-17-2018 05:01 PM
Engine noisy at initial startup after cam install warbird458 Engine Related 6 07-12-2016 11:50 AM
Engine noise after cam install? Brianu1 Engine Related 1 09-03-2015 12:38 PM
Break-in Before Tune After Cam/Piston Install? Screamin' Engine Related 4 04-10-2015 11:19 PM
Stereo issues after amp install HDRG13 Audio 28 12-22-2014 11:08 PM
