cylerama-575 cam upgrade.. - Road Glide Forums
 2Likes
  • 1 Post By eddienelson
  • 1 Post By hi
post #1 of 9 (permalink) Old 01-27-2018, 07:11 PM Thread Starter
just installed the Cyclrama -575 , with S&S lifters and pushrods, and new Thundermax download, boy what a difference really pleased with this setup, bike has plenty of low end grunt all the way up the RPM range...
hi$toy is offline
post #2 of 9 (permalink) Old 01-27-2018, 08:52 PM
eddienelson's Avatar
Man Ive heard a lot about that cam. If you dyno it please post the results. I'd love to see it.
ChromeSpark likes this.
2016 RG Custom Vivid Black
eddienelson is offline
post #3 of 9 (permalink) Old 01-27-2018, 10:43 PM
I have the 575 in my bike. Not sure what motor you have, mine is a S&S 106. Pulls real hard down low and doesn't fall off.
No PMS at all.
Tuned in real nice from what I was told. Very happy with the whole package
phillyfan1 is offline
post #4 of 9 (permalink) Old 01-28-2018, 06:51 AM Thread Starter
took out a set of Andrews 54 h and replaced with the 575, really sweet cam, bike is 2013 Roadglide with Rinehart Slimline headpipes,and 4 inch mufflers and S&S big sucker type airfilter, really like way these cams work, TRY IT YOU WILL LIKE IT....
hi$toy is offline
post #5 of 9 (permalink) Old 01-28-2018, 09:39 AM
2013 FLHX Stage II
This is with a Cycle Rama 575 cam set, SE A/C, V&H Power Duals, Klock Werks 4" slip on's with 2" baffles.
Red was with a stock cal and a Dobeck tuner after cams installed.
Blue is after the dyno tune.
File Type: png CR 575 V&H Power Duals, Klock Werks 4 slip onS.png (139.5 KB, 98 views)
George W is offline
post #6 of 9 (permalink) Old 01-28-2018, 10:41 AM
Originally Posted by George W View Post
2013 FLHX Stage II
Thats pretty impressive with no head work or compression increase etc.
post #7 of 9 (permalink) Old 01-28-2018, 04:07 PM
tj316's Avatar
I did the CR 575 in my bike when I had the 103 motor in it. I have the Dyna sheets somewhere. When it was a 103, air cleaner, TTS tuner and 2-1 pipe I was 100/100, later I did heads and was 115/115 or something close to that. The bike pulled early and long. It is a great cam.
tj316 is offline
post #8 of 9 (permalink) Old 01-28-2018, 05:54 PM
BlazingSaddle's Avatar
Saw where Scott from @Hillsidecycle.com mentioned the CR 575 in your post asking about cam upgrades. Glad you got it figured out. Heard and seen only good things about the 575 when used in the correct application; not a good choice in higher compression motors.
What didnít you like about the Andrews 54H compared to the CR 575?
BlazingSaddle is offline
post #9 of 9 (permalink) Old 01-29-2018, 05:07 PM Thread Starter
did not realize the 54h was in bike till teardown. Cam was soft on bottom end from 3000 above pulled ok, but 6th gear was useless till above 65 mph and then it lugged somewhat, probably ok for interstate but I live in lower North Carolina and do not do much interstate riding, unless taking a trip. Will be glad to let someone hold the 54h cheap...
BlazingSaddle likes this.
hi$toy is offline
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 07:47 AM
Wild 1 WO 575 vs WO 515 Coolblue Controls & Handlebars 17 06-22-2013 08:15 PM
11 FLTRX CR-575 cams tj316 Dyno Results 13 07-05-2012 10:31 PM
cycle-rama 575 or woods tw-777 hognit Engine Related 9 11-02-2011 03:00 PM
cyclerama 575 allofus81 Engine Related 4 03-05-2011 11:39 PM
