New Compensator or Compensator eliminator - Road Glide Forums
 3Likes
post #1 of 12 (permalink) Old 02-18-2018, 03:16 PM Thread Starter
Hello, time for a Compensator upgrade on my 2010 RGC. been reading a lot about upgrading to a SE Conp, or Baker. Also reading on the Vulcan works eliminator. Was curious if I can get pros and cons from you guys who have experience with this. I got 50000 miles on her and ride long trips. I just want a reliable and comfortable fix. Thanks for any info.
Also PS, any preferences on clutches, while I have her open......
Also should have added that she is a completely stock 96 other than pipe,air, and tuner. But if I cannot afford a new bike a upgraded displacement could be in my future.
mrmoto95 is offline
post #2 of 12 (permalink) Old 02-18-2018, 03:28 PM
Wood's Avatar
Look at your inner primary bearing; any pits, grooves, etc. replace. Also look at the rubber grommet on the wires for the alternator, front of primary, they do breakdown and then weep oil. Unfortunately you have to replace the alternator for this fix.
mrmoto95 likes this.
Wood is offline
post #3 of 12 (permalink) Old 02-18-2018, 07:05 PM
Thermodyne's Avatar
As for to comp or not to comp, that depends on what the scooter is used for. For a scooter making less than 120/120, that is used for more than a few thousand miles a year, I think you should run the comp. All of the wear and tear on the comp prevented wear and tear elsewhere. But that's a personal choice.
As to which comp, you'll need to check the sprocket shaft run out first. I like the Baker comp better and the SE. But the Baker comp is not very tolerant of run out in the crank. The SE makes more noise after the new wears off, but holds up better on a high run out shaft.
While you are in there, think about swapping out to an adjustable chain tensioner.
Thermodyne is offline
post #4 of 12 (permalink) Old 02-18-2018, 07:15 PM
Are you talking about the Baker manual chain tensioner ? I also looked on Baker's Web page and it says they are back ordered till some time in 19. I wonder if they are re-engineering their comp.
post #5 of 12 (permalink) Old 02-19-2018, 12:18 AM
Thermodyne's Avatar
That would be one choice. I run that one and I'm not totally happy with it. When I put the upgrade kit on it, there was some pretty obvious signs of deflection. And I'm not convinced the kit is enough to stop it. Also every time it needs more than an adjustment, the chain has to come off. And like the old adjusters, the teeth are a little course to always get a good adjustment. Were I to need a new one I would probably try the V-Twin piece.
V-Twin Manufacturing - This kit allows precise adjustment of the primary chain and creates less drag and loss of power resulting from the stock spring loaded assembly.
As to what Baker is up to, I'll have to call and find out.
post #6 of 12 (permalink) Old 02-19-2018, 06:20 AM
FDR's RGC's Avatar
I've got 50k on the Vulcan on my 2010 RGC with no problems. 10k with FM 107 kit.
Mike U likes this.
FDR's RGC is online now
post #7 of 12 (permalink) Old 02-19-2018, 06:40 AM
Stoic Joker's Avatar
I've got about 15k on the SE comp in my 10 and am quite happy with it. I do have a tendency to launch her quite hard rather often, but it's so far showing no signs of wear.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #8 of 12 (permalink) Old 02-19-2018, 03:23 PM
MyGlide's Avatar
Any differences in how it feels at lower rpms with the Vulcan as opposed to a comp? Been thinking about switching mine out to a solid sprocket next time around.
2018 KTM Super Duke R
MyGlide is offline
post #9 of 12 (permalink) Old 02-19-2018, 05:47 PM
FDR's RGC's Avatar
Any differences in how it feels at lower rpms with the Vulcan as opposed to a comp? Been thinking about switching mine out to a solid sprocket next time around.[/QUOTE] Not that I noticed. It does have 95K miles and never been faster.
post #10 of 12 (permalink) Old 03-11-2018, 07:40 PM Thread Starter
Did you have to change your rotor for that? If so what did you do?
mrmoto95 is offline
Twin Power 34 Tooth Compensator Eliminator Install Hawkeye1 Engine Related 43 10-11-2019 07:56 AM
Crash bar eliminator? housei *General Road Glide Discussions/Pictures 14 08-22-2014 07:29 PM
engine guard eliminator runmanpkll *General Road Glide Discussions/Pictures 11 06-21-2011 02:53 PM
RG Crash Bar Eliminator xusnatc Classifieds Archive (3 months old+) 4 02-16-2011 12:33 PM
crash bar eliminator install? housei *General Road Glide Discussions/Pictures 5 02-16-2011 06:24 AM
