Breather inside the rocker box - Road Glide Forums
post #1 of 6 (permalink) Old 02-20-2018, 07:37 PM Thread Starter
I took off my rocker boxes off to get powder coated, and I just got them back today. When I was ressassembling everything I was tightening the bolts for the oil breather and 1 of them blew out the bottom of the hole. Has anybody every had this happen to them? Do I need to replace the head now? Or would i be ok to just use high temp pipe tape on the treads. Any help would be great. Thanks
patztruck is offline
post #2 of 6 (permalink) Old 02-21-2018, 10:17 AM
Thermodyne's Avatar
Don't see how it could happen, unless something changed in the stack height. You have a gasket, the lower box, the rocker support, then a gasket and the breather stack. Nothing should have changed. Unless something fell down in the hole.
I would just use sealer on the bolt as a fix. A little Three Bond would fit the bill.
Thermodyne is offline
post #3 of 6 (permalink) Old 02-21-2018, 05:07 PM
MightyWhitey's Avatar
Isnít that secretly what Yamaha uses, and calls it yamabond...or something like that? If it is then itís Good shit for sure and thatís what I would use.
MightyWhitey is offline
post #4 of 6 (permalink) Old 02-21-2018, 05:54 PM
Smarty's Avatar
I sent you a private message.
2016 RGS Black Quartz
Smarty is offline
post #5 of 6 (permalink) Old 02-21-2018, 06:48 PM
Thermodyne's Avatar
Can't say that its the same, but it does the same job.
post #6 of 6 (permalink) Old 02-26-2018, 09:55 PM
Desertwndrr's Avatar
Oil in the hole will hydraulic and blow it out. Personally Iíd replace the head. Not sure that you can get a welder in there to fill it.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
Harley OEM Rocker box covers wrinkle black longrides Parts for Sale 2 01-24-2015 08:03 AM
Removing Rocker Box Cover Q-Hog Engine Related 2 03-12-2013 04:22 PM
Rocker box question?? 68 EB Engine Related 2 03-09-2013 01:54 PM
Twin Cam Rocker Box Covers Shrug Parts for Sale 0 02-26-2013 08:46 AM
Gloss Black HD Detachable Sissy Bar/Rocker Box Covers/Cam Cover Bigdaddymike Classifieds Archive (3 months old+) 7 01-26-2012 04:27 PM
