Horsepower vs Belt - Road Glide Forums
post #1 of 9 (permalink) Old 05-18-2013, 07:54 PM Thread Starter
jack6hd's Avatar
Horsepower vs Belt
Will higher HP reduce the life of the drive belt? I know riding habits are a factor. How much HP can the OEM belt take?
2015 FXDL 2nd best HD on road
jack6hd is offline
post #2 of 9 (permalink) Old 05-18-2013, 08:07 PM
glide69's Avatar
my turbo v-rod took 165 hp had 50k on it when traded in for the glide and she was rode hard and put away wet!!!
2018 FLTRXS Wicked Red
glide69 is offline
post #3 of 9 (permalink) Old 05-18-2013, 10:03 PM
JacktheBagger's Avatar
I know of one blown bagger at 200 with the belt , for peace of mind I would have a chain
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 9 (permalink) Old 05-18-2013, 10:10 PM
spokanebagfan's Avatar
[QUOTE=JacktheBagger;464966]I know of one blown bagger at 200 with the belt , for peace of mind I would have a chain
JtB
[/QUOTEnot sure of stock belts but some are stronger than the best chains made and much longer life.
spokanebagfan is offline
post #5 of 9 (permalink) Old 05-18-2013, 10:39 PM
caboverbob's Avatar
Not sure who makes HD belts for them, but they are made to HD spec requirements. I do know that a Gates Polychain will take whatever HP/torque/abuse you can throw at it with a street rideable bike.
I converted my '03 Nightrain to chain with sprotor setup for cool factor, nothing to gain on a bagger IMO.
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #6 of 9 (permalink) Old 05-18-2013, 11:03 PM
weakest link in a new bagger is the crush drive back on the rear pulley. the belt can take about anything but a rock
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #7 of 9 (permalink) Old 05-21-2013, 11:14 AM
If my drive belt ever goes.....wether it be a rock or torque I will be installing the sidecar belt which is 30% stronger then the OEM belt.
post #8 of 9 (permalink) Old 05-21-2013, 10:50 PM
My Boss Hoss had a 355 hp Chevy ZZ4 350 cid with a belt. Never had a problem. I sold it to a fellow who drags it and runs nitro - still the same belt. My other Boss was Chev 327 rated at 375 hp. It had a chain but I could tear the chain off at will.
BART
BART1 is offline
post #9 of 9 (permalink) Old 05-21-2013, 11:29 PM
I also have had several Boss hoss' 500hp big block no problems Ls3 Vette motor on Nitrous no problems!!!! adjust your belt properly and it is all good
Mike
thekidd is offline
Stock vs Arnott vs Legends vs HD Premium SEUGOT1 Suspensions 15 04-25-2017 11:10 AM
HorsePower Inc 51MM BLACKHAWK ECM/Fuel Management systems 0 01-08-2017 07:17 PM
Thundermax vs DynoVision vs PwrPro Black vs FP3 stillsoldier4christ ECM/Fuel Management systems 16 10-01-2016 01:42 AM
Horsepower Inc Peewee *General Road Glide Discussions/Pictures 9 03-23-2012 09:12 PM
Belt Guard Removed hotrodad *General Road Glide Discussions/Pictures 14 05-03-2010 08:20 PM
