Twin Power 34 Tooth Compensator Eliminator Install - Road Glide Forums
 20Likes
post #1 of 44 (permalink) Old 02-24-2018, 09:56 AM Thread Starter
Hawkeye1's Avatar
Post Twin Power 34 Tooth Compensator Eliminator Install
Last week I installed the Twin Power 34 Tooth Compensator Eliminator Sprocket and the Twin Power Manual Primary Tensioner.
Installation:
Very easy, instructions were clear from Twin Power for both the sprocket and manual tensioner install.
I had to loosen the clutch pack which was easy on the 2016 Road Glide Ultra. Just remove the large snap ring in the center of the clutch pack, remove the large rod, then using the Jim's sprocket locking tool, loosen the clutch pack locking nut (clockwise to loosen and counter clockwise to tighten).
Make sure to loosen the SE compensator bolt first, but don't remove the compensator assembly when loosening the clutch pack nut. This made it easier for me to put things back together.
The Road Glide Ultra has the 3 1/4 inch compensator bolt and requires the use of the large tapered washer when installing the sprocket (large flat washer goes inside of the sprocket and against the rotor housing). The large tapered washer goes on the outside the of the sprocket with the tapered facing out and the flat side against the sprocket.
Torque to 145 to 165 ft pounds. I torqued mine to 160 ft pounds.
Install the large rod back into the clutch, reinstall the center thrush bearing (I think that's what its called), then reinstall the snap ring.
The tensioner install that after installing the sprocket. I didn't get that special wrench with this tensioner kit. No big deal, I used needle nose vise grips to gently move the adjusting nut, just below the tensioner shoe. The locking nut using a 9/16th open box wrench. Hold the adjusting nut with the needle nose vice grips, then use the 9/16th wrench to lock down the adjustment once you have the tension you're looing for. I adjusted my tension to 5/8" slack.
Performance: Well, I've had this now on for 500 miles. Testing is pretty easy as I commute 124 miles round trip every day to work. I will let you know that the tensioner shoe makes a whine initially for a few hundred miles, not anything obnoxious, but definitely noticeable. It settles down and you don't hear it too much. I hear it on start up and then the sound goes away.
I can definitely feel a difference in the friction zone. I feel more control of the friction zone with this Twin Power Sprocket. Before the friction zone felt pulsating and I would say this was due to the SE style compensator. Also acceleration, much more impressive now, very snappy, but not jerk your head snappy. I have 32,000 miles on my 2016 Road Glide Ultra and she performance like I've added cams or increased air flow. I had S&S easy start 585 cams and Arlen Ness Inverted Big Sucker. Had to remove the cams and other things due to water and salt entering the engine. That is another post for another time. I learned a lot from that experience.
Back to the Twin Power 34 Tooth Compensator Eliminator Sprocket - YES, that garbling noise in the primary is now GONE. She fires up immediately, no hesitation, no couple of cranks. NOPE just hit the start switch and vroom.... and potato potato... Nice.
I've attached the photos of my install, I can say I'm very glad and very happy that I made this switch! The only time I feel any engine pulses is when I'm sitting in my driveway, bike is in neutral and I'm holding the rear brake. My driveway has a slight incline and I can feel just an every so slight pulse.
Stop and go traffic seems to be much easier, the clutch is easier to engage, neutral is easy to find when she is running. The biggest difference, when I accelerate, she has no lag, no more compensator noise and very responsive.
I'll keep you posted as I rack the miles, but I expect this to continue to make me smile!
I hope you find this helpful if you are thinking about doing something similar.
Hawkeye1 is offline
post #2 of 44 (permalink) Old 02-24-2018, 11:01 AM
Road dawg's Avatar
How many dead presidents did this set you back Hawk? looks like a real quality piece, did they give you any info on when to adjust this set up?
Road dawg is offline
post #3 of 44 (permalink) Old 02-24-2018, 12:35 PM
Smokey's Avatar
Excellent write up Hawk. This install is definitely something I am going to consider. Thanks for sharing and please keep us posted if you experience any issues or regrets as you pile on the miles.
Smokey is offline
post #4 of 44 (permalink) Old 02-24-2018, 07:39 PM Thread Starter
Hawkeye1's Avatar
@Road dawg : I got the two parts at Eastern Performance. The Compensator Eliminator Sprocket was $179 and the Manual Tensioner was $195. Total cost $374, smile on my face, priceless! As for the adjustment on the manual tensioner, Twin Power recommends checking after the first 5,000 miles and then based on speed of wear adjusting how often review from there. I'll check in about another 4,200 miles, I'll take pictures and report the break in and wear.
@Smokey : Thanks, hoping someone can use the information. After 5,000 miles I'll be adding the S&S Easy Start 585 cams. Right now she scoots and with the 585, I should feel noticeable improvements from 3,000 and up on the RPM.
I'll take pics and repost at 5,000 miles.
Road dawg likes this.
Hawkeye1 is offline
post #5 of 44 (permalink) Old 02-25-2018, 01:07 PM
Very cool, thanks for this info. I need to do something, this could be my route
mrmoto95 is offline
post #6 of 44 (permalink) Old 02-25-2018, 01:51 PM
Road dawg's Avatar
Thanks again Hawk, if i need to change my compensator in the future this is my go to for the upgrade, keep us posted. One more question Hawk, did you have an issue with the compensator and how many miles on your shark? Just curious.
post #7 of 44 (permalink) Old 02-25-2018, 08:17 PM
JacktheBagger's Avatar
good deal , will check into this one ..
2011 Ultra
JacktheBagger is offline
post #8 of 44 (permalink) Old 03-05-2018, 05:59 PM Thread Starter
Hawkeye1's Avatar
Sorry for the late reply, was out of town for work and unfortunately couldn't take the Road Glide for my travel. Would have been nice, Fredericksburg, VA to El Paso, TX.
@Road dawg : I did have a lot of noise with my compensator. I had 31,000 miles on my 2016 Road Glide when I swapped out for the Comp Eliminator Sprocket. Around 15,000 miles I started noticing a lot of metal on my dimple magnet plug when pulled off the outer primary. I started to change my primary oil every 5,000 miles instead of 10,000 to see if the condition continued. The very fine metal continued to be noticeable on the dimple magnet plug. I've own this Road Glide since new, only had 2 miles when I bought it at the Blue Spring Harley Davidson in Kansas City, MO. Road her back home to Fredericksburg the first week.
I will say that I have over 900 miles now on the new compensator eliminator sprocket and tensioner. The whine has almost disappeared, the start up and shut down is extremely smooth and the roll on acceleration is AMAZING! Very quick acceleration from 65 to 90 in almost what seems just a second or two with no hesitation.
So far, couldn't be happier with this upgrade! I'm going to change the primary oil again at 5,000 and take off the primary cover. I'll also take a picture of the dimple magnet plug and post. I'll take a picture of the compensator that I pulled off my 2016 Road Glide and post too.
I'll keep everyone posted!
Hawkeye1 is offline
post #9 of 44 (permalink) Old 03-05-2018, 06:15 PM
Nice !
post #10 of 44 (permalink) Old 03-05-2018, 06:54 PM
eddienelson's Avatar
Thanks for the write up. Im at 20k miles on my 16. Now Im wondering if I need to do mine.
2016 RG Custom Vivid Black
eddienelson is offline
Tags
twin power sprocket
New Compensator or Compensator eliminator mrmoto95 Engine Related 11 03-28-2018 07:10 PM
FXRG Leather Pant Size 34 X 34 marquez7 Sold 3 08-28-2013 09:26 AM
cam install off a tooth ? Eddie3 *General Road Glide Discussions/Pictures 14 04-06-2013 09:45 AM
6'4" 34 inseam looking for windshield help... Veritas Windshields 26 07-27-2012 01:25 PM
V-Rod Headlites on a 34 Ford Neano62 General Off-Topic Discussions 0 03-27-2011 11:03 PM
