FM 107 build - Road Glide Forums
post #1 of 6 (permalink) Old 03-04-2018, 10:37 PM Thread Starter
Speedy540's Avatar
FM 107 build
Have my RGS sitting at a Harley dealership waiting for a Dyno run. I added FM 107 standard kit, Woof 999-6a cams, FM level b heads and a FM variable clutch.
File Type: jpg IMG_20180301_221213_330_1520224303449.jpg (1.00 MB, 69 views)
File Type: jpg IMG_20180301_220901_255_1520224481501.jpg (966.4 KB, 66 views)
PIN IT TO WIN IT!
Speedy540 is offline
post #2 of 6 (permalink) Old 03-05-2018, 08:24 AM
Money well spent. What tuner are you using? I guess you don't have a good indy to tune it?
phillyfan1 is offline
post #3 of 6 (permalink) Old 03-05-2018, 10:26 PM Thread Starter
Speedy540's Avatar
Using a power vision. My local Stealer loves them. Had a little issue yesterday. They called and said the map FM sent them was shutting the fuel off at 3500rpm. I called them today and they said they got a new map that was working and it was currently on the Dyno but wouldn't be done until the morning. What sucks is I'm heading to Houston, I'm from the Lawrence KS area, for work in the morning and am coming home Thursday. Good news is it's supposed to be sunny and close to 50 degrees when I get back so I can ride her home!
PIN IT TO WIN IT!
post #4 of 6 (permalink) Old 03-05-2018, 11:19 PM
Good deal! Sounds like they are going to break it in on the dyno also?
Enjoy it. I enjoyed putting mine together and the power. Im sure you will also
post #5 of 6 (permalink) Old 03-06-2018, 06:15 AM
eddienelson's Avatar
What compression did you go with? Ive also been curious about that cam. Can't wait to see the numbers.
2016 RG Custom Vivid Black
eddienelson is offline
post #6 of 6 (permalink) Old 04-22-2018, 07:20 PM Thread Starter
Speedy540's Avatar
Ended up buying a Thundermax autotuner. Tired of paying the dealershit and getting jacked around. Bikes running great but no numbers yet. It felt like it was running pretty good until I lined up next to my buddy on his stage 1 2016 road glide. That's when I realized it's running REAL good! I went with 10.5 compression. I couldn't be happier with it so far. Loving the cams!
PIN IT TO WIN IT!
2015 FLHX, FM 107, Level C heads, TW8-6 cams fuelmoto Dyno Results 21 07-04-2017 12:08 AM
2011 RG FM 107 Build 22 Phantom Dyno Results 6 10-05-2015 05:33 AM
3 minute engine build; FM 107 time lapse video fuelmoto Fuel Moto 2 02-06-2015 08:39 AM
FM 107" vs. HD Stg 4 kit Brianu1 Engine Related 11 08-15-2014 09:58 PM
FM 107/woods tw777 initial thoughts. eldridgetom Engine Related 10 02-22-2014 07:55 PM
