103 vibration above 3000 rpm after cams? - Road Glide Forums
 6Likes
post #1 of 23 (permalink) Old 05-21-2013, 03:50 PM Thread Starter
Put my 222 cams in at start of riding season. Bike seems to vibrate more above 3000 rpm in 6th gear than it used to? But- Im not really sure. I cant recall from last year if I had the same vibration before the cams or not? I may just be paying attn to it now- looking for something I may of screwed up. Call FM and they couldnt think of any reason the cams would start a new vibration above 3k.
So my ? is- do others 103's increase in vibration starting right about 3000- 3200 rpm?
Anything I should be checking?
Thanks
Mark
Fuel Moto header (no cat) Jackpot 2 1/2 mufflers, PV by Fuel Moto, BAL1, Woods 222 cam
baldwookie is offline
post #2 of 23 (permalink) Old 05-21-2013, 04:08 PM
teejay's Avatar
My 103 is bone stock right now and I feel what can best be described as a "buzz" in the handlebars between 2900 and 3200 rpm. Its not really noticeable in either the floor boards or the seat either.
I'm going to consider it as character unless it gets worse.
tj
teejay is offline
post #3 of 23 (permalink) Old 05-21-2013, 05:40 PM
faststan's Avatar
You are in the torque band at that rpm. Should be smooth as glass. Maybe your vibration is something other than the engine? At that rpm in 6th gear you are going over 80. Could be wheel balance, flat spot on tire(s) from sitting.......
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #4 of 23 (permalink) Old 05-21-2013, 05:56 PM
Harleyagain's Avatar
I have the same cam and its smooth as ice that rpm. Might look at your motor mount for a possible solution.
Bob
Harleyagain is offline
post #5 of 23 (permalink) Old 06-05-2016, 04:23 PM
DynoMike's Avatar
What was the solution to your problem? That's exactly what is happening to my bike with the same cams right now.
2011 FLTRX, Vivid Black
DynoMike is offline
post #6 of 23 (permalink) Old 06-06-2016, 06:53 AM
If it has not been tuned,(not a "canned" map) I suggest a tune.
Scott
Smarty and RFG7680 like this.
Hillsidecycle.com is offline
post #7 of 23 (permalink) Old 06-06-2016, 03:14 PM
Hi my bike is a Rg special 2015 i notice today after a long ride weekend a bad vibration on my bike,my dealer has mounted the v/h power duals the bike has almost 3000 miles and the 1000 mile service is done,and this is what i found, this could gone realy bad so look at this bracket that should hold the system attached to rear of transmisson it was near to cut the rear tire,my dealer have some explanation to do
ultra98 is offline
post #8 of 23 (permalink) Old 06-06-2016, 03:36 PM
DynoMike's Avatar
Thanks for the input. I found two issues with my exhaust. The bracket that holds the crossover pipe to the transmission was a little loose at the transmission. And the bolt that holds the exhaust pipe to the frame bracket was missing. I tightened everything up and replaced the bolt, now the problem seems fixed.
DynoMike is offline
post #9 of 23 (permalink) Old 06-06-2016, 03:51 PM
eddienelson's Avatar
WOW!!! I'm guessing your gonna get an I'm sorry and that's about it. I'm pretty sure you paid top dollar for that service. I'm glad you found the problem. Scary stuff there.
eddienelson is online now
post #10 of 23 (permalink) Old 06-06-2016, 04:10 PM
Thumbs down
yes it s expensive 500 dollar for service
ultra98 is offline
2500-3000 rpm vibration mouser58 Engine Related 1 11-15-2016 03:59 PM
Installed Duals, Engine vibration Below 2000 RPM bosshogg123 ECM/Fuel Management systems 2 09-12-2016 12:55 AM
Vibration RPM specific MShell Troubleshooting for Road Glides 5 03-13-2016 11:15 AM
RPM Related Vibration Cuzen Engine Related 8 11-14-2013 06:36 AM
Vibration above 65 mph. poochie49 Troubleshooting for Road Glides 17 11-06-2012 09:20 AM
