cam chain tensioner - Road Glide Forums
post #1 of 8 (permalink) Old 05-21-2013, 08:10 PM Thread Starter
cam chain tensioner
on a 2002 , at what interval should i check the cam shoes? i didn't find anything in the service manual .
cyclejuice is offline
post #2 of 8 (permalink) Old 05-21-2013, 10:25 PM
interval? ha, not specific to RG's, the glue different for us all.
reds4 is offline
post #3 of 8 (permalink) Old 05-21-2013, 10:41 PM
mitchdm's Avatar
Not sure of your miles but an 02 I would be very nervous with the old style (spring) after 25k ~ I have never run the new style (hydraulic) over 40k ~ I have not had a failure but have seen alot of wear at 40k on my previous bikes ~ On the 12 I installed the zippers and will see how they work out.
I ride with guys that have run the old and new style over 100k ~ my luck just does not seem to hold out this long ~ They tell me I ride em too hard & fast
mitchdm is offline
post #4 of 8 (permalink) Old 05-28-2013, 11:21 PM
that bike's over ten years old, i'd just change them. did a friend's 2001 on the weekend, the outer tensioner pad had disintegrated, just fallen apart, not really worn through, just crumbled. bike has sat a lot though, only about 25000 miles on it.
wicked world is offline
post #5 of 8 (permalink) Old 05-29-2013, 06:14 AM
We've witness those fubared at 1200 miles, and still intact(barely)@ over 130,000 miles.
Not much to check those.
A dental mirror can be used to take a peek at the inner.
Scott
Hillsidecycle.com is offline
post #6 of 8 (permalink) Old 05-29-2013, 07:35 AM
tmd
I must be one of the lucky ones. When I sold my 01 Springer it had over 30k miles on it and the tensioners looked like new. When I sold my 05 RG with close to 30k the shoes in it were also barely worn.
tmd is offline
post #7 of 8 (permalink) Old 05-30-2013, 05:50 PM
prodrag1320
Guest
Posts: n/a
the problem is that the material is harder than alluminum,so even with almost no wear,they still disinagrate with little "pip" marks that get in your pump & score up the pump/cam plate.best to get them out with a gear drive or hyd. up grade
post #8 of 8 (permalink) Old 05-30-2013, 05:53 PM
On my 2002 fatboy I changed them at 40K and they still could have gone a bit longer. But...the set I put in then only lasted 20K miles so it is random. On my RG I just picked up the tensioners have 30K on them and look near new. On my Dyan I checked them at 33K and they were totally shot, cracked and ready to go.
I went to the Hydraulic S/E setup on both of these bikes. I will do the same to the RG when they need to be done.
HogPro is offline
My cam chain tensioner woes... Slyguy41 Engine Related 11 05-24-2014 05:59 PM
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 08:47 AM
Cam Chain Tensioner Help Z-SHARK Engine Related 3 06-01-2013 08:34 PM
Hydraulic chain cam tensioner kit ohd24 Engine Related 7 06-30-2012 08:24 AM
Cam chain tensioner question SKULLZ *General Road Glide Discussions/Pictures 5 05-14-2011 03:29 PM
