1340 engine wake up - Road Glide Forums
post #1 of 6 (permalink) Old 05-22-2013, 11:46 AM Thread Starter
glidelover69's Avatar
1340 engine wake up
Anybody have advice on waking up this 1340 on this 90 tour glide...everythings stock but i want to have some strong touring power, nothing to major, engine has 29,000 mi. Any help on where to start would be greatly appreciated!
1990
Tour Glide Ultra Classic
glidelover69 is offline
post #2 of 6 (permalink) Old 05-22-2013, 02:17 PM
prodrag1320
Guest
Posts: n/a
did you want to go bigger inches? if so a 97" is about the best touring motor you can build,VERY dependable as your staying with the 4.25" stroke,adding 3.812" bore cylinders.have mild,touring headwork done using 1.900 intakes (set @ 9.8-1)& add a CRANE H290-2 cam.we`ve done this build many times for touring bikes over the years with great,very high milage results (and a bike that will smoke most others on the street!!)
post #3 of 6 (permalink) Old 05-22-2013, 02:44 PM
Bigtrev8xl's Avatar
Leave it as it is and enjoy the journey.
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #4 of 6 (permalink) Old 05-22-2013, 04:37 PM
prodrag1320
Guest
Posts: n/a
that aint no fun!
post #5 of 6 (permalink) Old 05-22-2013, 10:46 PM
thedude's Avatar
A couple years ago I changed the cam in my 93. Made a noticable differance and was not a huge expense. I can not remember which one I put in. All I was looking for was to get it up to 85 fairly quick. Had a friend who works at a shop do it in his garage. Cost me $250 or $300 and a case of High Life.
thedude is offline
post #6 of 6 (permalink) Old 05-23-2013, 05:34 AM
If looking for a cam-only upgrade, then the BEST cam we've witnessed here for, again, a cam-only increase is a Crane 300-3B.
BIG increase in the torque for touring power.
Naturally a set of adj pushrods/gaskets/cam bearing, and I will make mention of the Moco bulletin that reccomends the lifters to "inspect and/or replace" @ 25,000.
Other options that push off more are easily established if willing to pull the heads, and as Kirby has already mentioned, an increase to either an S&S 96" Hot Set-Up, or a set of 3 13/16" cylinders upping it to 97", can easily have you over the 100/100 mark.
Scott
Hillsidecycle.com is offline
Tags
1340 , 1990 , engine , tourglide
One of the GREATEST WAYS TO wake up in the morning!!! DB DIESEL Paint & Bodywork Section 16 11-12-2013 08:33 PM
Whatever you do, don't wake me up. OldNerdGuy *General Road Glide Discussions/Pictures 31 06-04-2013 12:05 PM
1340 EVO motor upgrade my98glide Engine Related 26 01-05-2013 04:00 PM
WAKE UP video BillyBob Videos 0 09-11-2012 03:11 PM
wake up 09 se rg txscreamingeagle *General Road Glide Discussions/Pictures 1 07-07-2010 07:08 AM
