Engine clatter after warm and restarting. - Road Glide Forums
 5Likes
post #1 of 21 (permalink) Old 03-19-2018, 11:57 PM Thread Starter
Yesterday pulled the bike out and started it up to get it warmed up for a ride. Sounded fine at first start up. Shut it off went in house for 10 minutes. Come back out started it and had a knocking or rattle noise coming from the left side of bike. Jumped on it and about a mile down the road it went away. Rode about 150 miles and every time we stopped for a bit and restarted the bike it would make the same noise. I know itís not normal ! Never has made this sound before and it is loud over the exhaust. Any ideas ? Compensator or maybe a bad lifter. Bike has 300 miles on a stage 3 103 build. Called dealer and they are buried so wonít be able to get it in till Friday. Thanks for the help.
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #2 of 21 (permalink) Old 03-20-2018, 12:14 AM
Smokey's Avatar
Both the simptoms and the noice sound very much like the compensator to me.
eddienelson likes this.
Smokey is offline
post #3 of 21 (permalink) Old 03-20-2018, 06:20 AM
Road dawg's Avatar
Very well could be the compensator, bit I had that a while back and it was the lousy dreaded lifter failure, so ended up doing cams with S&S premium lifters and adjustable pushrods, and have been happy as a pig in slop since. Definitely have that checked out.
Road dawg is offline
post #4 of 21 (permalink) Old 03-20-2018, 07:19 AM
Swomack's Avatar
That would also be my guess
I have replaced my compensators twice
Once fixed the last time, Iíve had zero issues
Swomack
My Gallery / Click Below Link
Swomack is offline
post #5 of 21 (permalink) Old 03-20-2018, 07:44 AM
Smokey's Avatar
Swomack
I need to ask what you did to remedy your compensator issue Swo. I think Freedom and I are both going to need this information soon.
freedom1974 likes this.
Smokey is offline
post #6 of 21 (permalink) Old 03-20-2018, 07:49 AM
It could be the compensator, but that usually bangs and then goes away. My guess is a lifter or lifters. Mine had a rattle that wouldn't go away, and the lifters were bad. You only have 300 miles on the stage 3, so it very well could be related to that.
PeteF is offline
post #7 of 21 (permalink) Old 03-20-2018, 08:00 AM
Swomack's Avatar
The last fix we used shims on the new comp and I haven't had any issues.
The first two replacement were done without shims.
Sticking lifters also make noise until the oil heats up.
I wrote up a thread on bad comps somewhere
I'll try and find it
Swomack
Swomack is offline
post #8 of 21 (permalink) Old 03-20-2018, 08:17 AM
Swomack's Avatar
I found this old thread and you should read what I went thru
The last fix with the new comp & shims fixed the issues I had
Zero issues after putting another 20,000+ miles on my sled
Here is the link
Page # 8 was the final fix
Hope this helps
Swomack
https://www.roadglide.org/14-tech-are...2-weeks-8.html
Swomack is offline
post #9 of 21 (permalink) Old 03-20-2018, 08:55 AM
Smokey's Avatar
Here is the link
Hope this helps
Swomack
Great bit of info Swo. I am having the same symptoms as Freedom and am confident at least in my case that it is the compensator. Thanks brother, and Iím hoping Freedom benifits from the info as well.
Swomack likes this.
Smokey is offline
post #10 of 21 (permalink) Old 03-20-2018, 10:32 AM
Swomack's Avatar
Great bit of info Swo. I am having the same symptoms as Freedom and am confident at least in my case that it is the compensator. Thanks brother, and I’m hoping Freedom benifits from the info as well.
Yeah man
If it just the compensator, it’s an easy fix
Let us know how it turns out once the fix is done
Swomack
Swomack is offline
Stalling after warm up Deadstroke Engine Related 25 03-31-2017 02:57 PM
Engine Warm Up Period michaelgrudgings Engine Related 24 03-08-2017 10:13 AM
Occasional valve clatter at highway speeds Big D JTAC Engine Related 2 12-09-2013 09:31 AM
Changing your oil. Engine warm or cold? Minivend *General Road Glide Discussions/Pictures 19 04-13-2013 11:11 PM
How Warm is Too Warm? Ran8175 *General Road Glide Discussions/Pictures 5 03-19-2012 12:36 PM
