Noise in the primary - Road Glide Forums
post #1 of 10 (permalink) Old 05-25-2013, 08:30 AM Thread Starter
I just recently had my compensator replaced and had a Hayden tensioner put on. Bike runs amazing. But when the bike stops at a light, or at home, after its warm the bike makes a strange sound. Like a little clanging around. But my rpm's seem to be dropping to 800 when this happens. If I give it a little throttle it's gone. Anyone have any ideas before I tear it all apart?
2009 Hot Red Sunglo, 107 build, S&S 551 cams, heads polished and ported, Vance & Hines Dresser Duals, Vance and Hines 4" rounds, REVOLUTION PERFORMANCE ems, Bad Seed bars, J&M amp and rokkers speakers, Sony DSX-S310, progressive 940's
RoadGlide0611 is offline
post #2 of 10 (permalink) Old 05-25-2013, 08:46 AM
Hullhorr's Avatar
Did they check the inner primary bearing and race when they installed the Hayden tensioner? Is the noise coming from the Primary area?
2009 FLTR MOP
Hullhorr is offline
post #3 of 10 (permalink) Old 05-25-2013, 08:49 AM Thread Starter
Yes it coming from the primary. It only make noise at 800 rpm. As soon as you increase the rpm's noise goes away.
post #4 of 10 (permalink) Old 05-25-2013, 09:04 AM
Hullhorr's Avatar
I would check the inner primary bearing and race. It doesn't make a clanging sound when it goes bad, but the residual effects can. When the Primary bearing or Main gear bearing fail they can cause the teeth on the clutch basket starter gear to rub the inner wall of the inner primary case. Mine did this, but I had so many other noises going on it was hard to tell.
This would make sense to me since under load the noise goes away. You can easily check the main gear bearing at the same time as checking the inner primary bearing. If the main gear has any play at all it should be replaced. I went thru this on my 2009 a couple months back and was shocked by how many bearings were bad.
2009 FLTR MOP
Hullhorr is offline
post #5 of 10 (permalink) Old 05-25-2013, 02:09 PM
rageglide's Avatar
Another thought, the hayden is simple design with no damping and a fairly light spring taking up the slack in the chain. I would think if the initial spring preload was too light, combined with low RPM the pulses from the compensator could cause the primary chain to slap the tensioner.
Also, I found that switching out the POS auto tensioner to a Baker fixed shoe the lighter load on the primary chain made totally different noises. The overly tight primary chain whines and has no lash in the drivetrain. The fixed shoe makes zero whine and the drivetrain feels "looser". Not really sure how else to describe it.
2012 fltrx
rageglide is offline
post #6 of 10 (permalink) Old 05-25-2013, 03:01 PM
T-BO 399's Avatar
My guess would be chain slap at low RPM also. My main bearing went bad in my 09 not long ago and the noise was more of a scraping sound like a warped rotar might make. Also when I would pull on the clutch the noise would go away.
2009 FLTR, BLACK PEARL
T-BO 399 is offline
post #7 of 10 (permalink) Old 05-25-2013, 04:00 PM Thread Starter
I think that's what it is chain slap. Do you think that will improve. I rode the bike today and didn't hear it even once
post #8 of 10 (permalink) Old 05-25-2013, 07:39 PM
rageglide's Avatar
Bump the idle up and it'll probably quiet down. If that doesn't help could pop the primary open and make sure the hayden is shimmed correctly.
Also as I mentioned earlier you will hear different noises after swapping to a fixed tensioner. I got used to the new sound.
2012 fltrx
post #9 of 10 (permalink) Old 05-25-2013, 08:33 PM Thread Starter
Good advise.
post #10 of 10 (permalink) Old 05-25-2013, 09:35 PM
FLTR2008Trike's Avatar
You have your engine idling at 800 rpms?? That isnt good for the charging system to start. With the added draw of the fuel pump you should have it idling at 1000k for the fuel injection to work properly
Also if your hearing noise have you had the compensator checked or replaced? ITs possible the noise could be coming from that.
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
Inner primary whirling noise Wood Troubleshooting for Road Glides 4 03-16-2016 10:52 AM
Primary noise :( rlaf75 Troubleshooting for Road Glides 22 10-27-2015 11:50 AM
Another Primary Noise Thread Pork Chop Troubleshooting for Road Glides 6 04-19-2015 06:34 PM
noise in primary???? craig demel Troubleshooting for Road Glides 4 07-08-2013 12:30 AM
Loud noise Primary Beachjeep Troubleshooting for Road Glides 12 11-20-2012 05:06 AM
