Trouble with SE585 cams - Road Glide Forums
 5Likes
  • 2 Post By madmat
  • 1 Post By Desertwndrr
  • 2 Post By Big_gary
post #1 of 4 (permalink) Old 03-28-2018, 09:34 AM Thread Starter
Detroit Tony's Avatar
I just had my cams done at the stealership and here's what's going on:
at 4500 rpm she starts to shake up to 5000 it gets worse. I did the SE 585 cams, SE valve springs and lifters, all new. Used the SE pro street tuner.
Your feedback is welcomed. I know I am going to have the dealership solve this issue.
Thanks,
Detroit Tony
Detroit Tony is offline
post #2 of 4 (permalink) Old 03-28-2018, 10:40 AM
madmat's Avatar
Hi Tony, welcome from Mass.
Right back to the dealer, you paid for a service to be perfomed. They should deliver your bike running correctly.
RGKen and Swomack like this.
18 RGS Bonneville Salt Pearl
madmat is online now
post #3 of 4 (permalink) Old 03-30-2018, 09:24 AM
Desertwndrr's Avatar
Did they do a full dyno tune, or just a download? Bad tune can cause symptoms like you describe. Id have that checked before tearing things apart first. Next thing would be to check and ensure that the cams are timed correctly and they dont have a tooth off plus put a micrometer on the crank to check runout.
Good luck.
Swomack likes this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #4 of 4 (permalink) Old 03-30-2018, 06:08 PM
What year bike ? If it's a Twin cam , dump the Street turner. You'll never get a great tune staying with in epa compliance.
Swomack and RFG7680 like this.
Big_gary is online now
103 stock heads stock TB 11.0 pistons SE585 cam. Tuned by Stroker freedom1974 Dyno Results 8 02-01-2018 10:38 AM
2015 fltrxs se585 Hdbigfoot Dyno Results 3 12-15-2017 08:43 PM
cams,cams,cams dozer23 Engine Related 2 03-03-2017 08:18 AM
SE259e vs SE585 ScottyG Engine Related 4 02-27-2017 11:27 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 08:58 AM
