Engine upgrade - Road Glide Forums
 4Likes
  • 1 Post By Genzer
  • 1 Post By wevsspot
  • 2 Post By eddienelson
post #1 of 8 (permalink) Old 04-07-2018, 05:16 PM Thread Starter
Engine upgrade
Need some help here, bike is a 16 RGS 103 screaming eagle breather with true duels. I'm looking at either the SE 585 kit or the Cyclerama 570 or 575 cams and upgrade springs lustrous from S&S. which will give me the better performance? and will I notice it that much? Also I'll be doing my own work
Genzer is offline
post #2 of 8 (permalink) Old 04-07-2018, 05:21 PM Thread Starter
Dam spell check! S&S pushrods
Genzer is offline
post #3 of 8 (permalink) Old 04-09-2018, 04:52 PM
08Zinc's Avatar
Got the Woods 555 cams and am pleased. Don't know the specs of the 2 you mentioned. One thing to look at is your SE breather. Which one do you have? I had the ventilator and it was pretty restrictive. Changed it out to a NESS Inverted Big Sucker to go with a 2-1-2 Jackpot exhaust system from Fuel Moto. The cams helped that much more. YMMV
Blessings, Zinc -
08Zinc is offline
post #4 of 8 (permalink) Old 04-10-2018, 09:03 AM Thread Starter
08Z, it's the extreme billet air cleaner, I had a Ness big sucker on my '10 ultra , they look identical.
08Zinc likes this.
Genzer is offline
post #5 of 8 (permalink) Old 04-10-2018, 09:22 AM
Momania's Avatar
I have Cyclerama 575 cams, plenty of power and torque in any gear be it single or two up riding.
Momania is offline
post #6 of 8 (permalink) Old 04-10-2018, 09:27 AM
wevsspot's Avatar
The CR570 and CR575 are getting rave feedback at another HD forum.
Our good friend @eddienelson swears by the Andrews 57H if you don't mind going with a thinner head gasket to bump compression up just a tad. His bike runs really well. I have to make sure I beat him in the twistys or he walks off and leaves me.
eddienelson likes this.
wevsspot is offline
post #7 of 8 (permalink) Old 04-10-2018, 09:33 AM
I also have the CR 575 and for my build, they are exactly what I was looking for. If you got to the tech forum under dyno sheets you can find some sheets on them. Sheffer performance uses a lot of them and post a lot of sheets using the CR cams.
Are you going to do anything else to the motor? If so, those things should be considered. Lots of great sheets on the 570-2 cams in 103's.
Talk to Darren at Sheffer and see what his thoughts are and if the 575's will work for you. I did and I am 100% satisfied with them.
phillyfan1 is online now
post #8 of 8 (permalink) Old 04-10-2018, 09:37 AM
eddienelson's Avatar
Ok you put a little gravy on that one!lol I will have to say there has been a couple of times that I lugged the bike pretty bad in the hills trying to keep up with wessspot but the Andrews pulled thru with no problems. I do have a set of Tman 600's Ive been wanting to try but damn the bike is running so well I hate to mess with it. I personally think all the cams mentioned will serve you well. For the most part its 6 here or half a dozen over there. Tuning is key...
gplatt58 and Nutt2336 like this.
2016 RG Custom Vivid Black
eddienelson is offline
Best engine upgrade for 110" '13 CVO? Batbiker Engine Related 28 01-25-2013 07:36 PM
Engine upgrade, I need suggestions... willbglidin Engine Related 6 11-09-2012 10:43 AM
Cam/engine upgrade... ZachB Engine Related 10 04-04-2012 01:12 PM
Engine Upgrade ??????????? TearlessTom *General Road Glide Discussions/Pictures 18 11-10-2011 08:09 PM
Weigh in on Potential Engine upgrade mtglide *General Road Glide Discussions/Pictures 5 09-05-2010 05:15 PM
