Cams/Performance upgrade? - Road Glide Forums
 5Likes
post #1 of 19 (permalink) Old 04-17-2018, 12:08 PM Thread Starter
jlmowry's Avatar
I've been pouring through the various threads looking at cam info, but I thought it would be more helpful to start my own.
Cams are among my list of upgrades so my decision starts here. I have 2016 RGS with V&H FP3, V&H Power Dual Headers, V&H High Output slip ons, and a RSD Slant AC. Most of my riding is 2 up, and a good chunk of that is with king tour pak loaded for long trips. I live in Wyoming so lots of mountain riding but plenty of flat country in between. I don't plan on increasing the size of the motor. Also, aside from cams, not sure what other performance mods I should do? So, I'm asking for all your thoughts/experiences on what cams I should go with and for any performance upgrades.
Thanks,
Jim
jlmowry is offline
post #2 of 19 (permalink) Old 04-17-2018, 12:12 PM
Definitely worth your time and effort to give Fuel Moto (https://www.fuelmotousa.com/) a call and get you headed in the right direction. They have a lot of dyno charts on their page as well that you can browse and get an idea of what gains you're looking at.
Best of luck and let us know what you decide!!!
ironmark and canukHD like this.
RoadglideinMO is offline
post #3 of 19 (permalink) Old 04-17-2018, 04:13 PM Thread Starter
jlmowry's Avatar
Thank you for chiming in. I'd been to their site and will go back over, check it out and make the call.
Jim
jlmowry is offline
post #4 of 19 (permalink) Old 04-17-2018, 04:51 PM
MightyWhitey's Avatar
Where are you from Jim?
MightyWhitey is offline
post #5 of 19 (permalink) Old 04-17-2018, 04:54 PM
08Zinc's Avatar
Jim, given that you ride 2 up a lot and in mountains, I would think that you would want a cam that hits low in the RPM band to be the most useful. Something like a Woods Prowler .222 or even the Harley .255. I had the 255 in a Ultra Classic that I had bumped to a 103 from a 96 and really liked the low end pull.
+1 on calling Fuel Moto. They recommended the Woods 555 cam for my current bike and I am very pleased with it, but that's my riding solo in hills, not mountains.
Blessings, Zinc -
08Zinc is offline
post #6 of 19 (permalink) Old 04-17-2018, 04:54 PM
I'm sort of in the same boat as you Jim, except I ride one up most of the time. When it is just me, my bike is fine, but it's when the wife and I add the tour pak and load up for longer trips, I notice the need for a little more oomph. I am not a very mechanical person and don't understand things like compression, lift etc. I just know that I'd like to have a little more power available when we are touring. I'd also like to get better gas mileage too!
Running just about the exact setup as you Ė v&h power dual headers, screamin eagle mufflers, big sucker AC, and FP3.
Let me know what you find out!
macabra11 is offline
post #7 of 19 (permalink) Old 04-17-2018, 08:09 PM
Check out the tech forum. Lots of dyno sheets there. Lot of pro engine builders over there with tons of knowledge of what works for what you want. CycleRama 570-2 is the hot bolt in cam over there for a bolt in cam that pulls hard down low.
phillyfan1 is offline
post #8 of 19 (permalink) Old 04-17-2018, 09:44 PM Thread Starter
jlmowry's Avatar
I live in Sheridan, WY. Closest dealer is 130 miles and no indy’s that I’m aware ofthat I’ll let wrench on my bike.
jlmowry is offline
post #9 of 19 (permalink) Old 04-18-2018, 06:12 AM
eddienelson's Avatar
Look at Tman cams. The 555 and the 600sm.https://tmanperformance.com/product/...-555-torqster/ Both cams designed for 2 up curvy mountain roads. Im running the Andrews 57H and when we go to NW Arkansas riding 2 up I have lugged my engine many times. Sometimes on purpose and sometimes by accident and the 57 always pulls strong. I did change the head gasket out and bumped the compression up to 10.1:1 from the stock 9.7:1.
2016 RG Custom Vivid Black
eddienelson is offline
post #10 of 19 (permalink) Old 04-18-2018, 06:14 AM
Originally Posted by jlmowry View Post
I live in Sheridan, WY. Closest dealer is 130 miles and no indyís that Iím aware ofthat Iíll let wrench on my bike.
If youíre going to do the work yourself Iíll send you my cam bearing tools to borrow and trust that youíll send them back.
Stage III 103 to 110 or Stage III Performance Upgrade? javal2001 Engine Related 0 06-04-2017 02:27 PM
cams,cams,cams dozer23 Engine Related 2 03-03-2017 08:18 AM
CVO 110 Performance Upgrade smitty2u Engine Related 44 04-19-2012 03:09 PM
Wood performance cams JKRSDETROIT Classifieds Archive (3 months old+) 4 04-16-2012 04:42 PM
