Compression Releases Yes or No.... - Road Glide Forums
post #1 of 14 (permalink) Old 06-01-2013, 12:14 PM Thread Starter
direwolf's Avatar
Last May I decided to go ahead & pull the trigger on the 107 Big Bore upgrade on my 08 RoadGlide, I ended up doing cam, new screaming eagle jugs (polished & ported of course) bigger valves, PV-1 & autotune. No compression release though as I thought I could save some coin. Well after installing a new starter, compensator in the first year I figured the problem was gone.
Wouldn't you know it 2 weeks ago after fueling up I went to start her up (hot start) and ended up taking the starter clutch out & had to have it towed to the shop. I did get a new starter under warranty from Drag Specialties, but ended up spending a lot more coin having the CR's put in now then if I'd have not been so cheap when I had the original work done. Funny thing is I knew I should have had them done when I was doing the stage III on it. Oh well live & learn, just had to share my stupidity with someone.
Ride Safe
...2009 SERG...Last of the Hand Built's..
direwolf is online now
post #2 of 14 (permalink) Old 06-01-2013, 01:37 PM
panhead's Avatar
Get it done. Will never have a problem with it again.probably never replace the starter clutch again either.I did itin my 09 103 made all diffetence in the world.it was really bed when I had the 255 cams in that bike. No auto releases in the heads until 2011 I believe.
2011 COOL BLUE PEARL FLTRX , 120R,
too much to list...
panhead is offline
post #3 of 14 (permalink) Old 06-01-2013, 01:38 PM
Yes, go for it. I'm glad my bone stock 103 came with the ACR.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 14 (permalink) Old 06-01-2013, 01:49 PM
The only way I wouldn't go with CRs would be if I had S&SE cams, which is just like having CRs.
post #5 of 14 (permalink) Old 06-01-2013, 01:51 PM
rageglide's Avatar
It's easy to look back and realize what you should have done differently. Unfortunate, but true.
So I'm not sure, but are you saying you Did get CRs installed since or that you now realize you should have?
If you haven't added CRs, you can try going the travel limiter route, it's very cheap if you can get them for your lifters, otherwise S&S sells lifters with them installed. They do help a lot and if you're just on the hairy edge they may be sufficient. My evo stroker has no CRs and only travel limiters and it's got ~190ccp. It never kicks back, even with the original starter (20yrs and 110k miles).
2012 fltrx
rageglide is offline
post #6 of 14 (permalink) Old 06-01-2013, 02:12 PM
prodrag1320
Guest
Posts: n/a
put them in,their well worth it
post #7 of 14 (permalink) Old 06-01-2013, 04:19 PM Thread Starter
direwolf's Avatar
Just had them installed this past week, world of difference in starting. In fact I usually pop them down after I shut it off so I can just start it & worry
post #8 of 14 (permalink) Old 06-01-2013, 04:34 PM
rageglide's Avatar
Ok, cool. It's really nice to have the peace of mind. It really sucks stopping for gas and having to cross your fingers.
BTW I was only suggesting travel limiters as a interim fix, I too feel strongly CRs are the real solution.
2012 fltrx
post #9 of 14 (permalink) Old 06-01-2013, 04:41 PM Thread Starter
direwolf's Avatar
I figured you meant that. Funny thing is I knew better and ended up proving my own point
post #10 of 14 (permalink) Old 06-01-2013, 05:49 PM
connector's Avatar
When i had the 255s in the bike i had them installed as i thought of them as a sort of cheap insurance. Now with the 590s in i still use them every time i stop, its automatic push em down.
09 FLTR 103 Stage III
connector is offline
Compression releases not closing Reddobe1 Engine Related 9 08-03-2015 06:12 PM
Compression releases sj01fltri Engine Related 7 01-07-2015 07:10 PM
Install compression releases with heads on the engine? Reddobe1 Engine Related 12 04-30-2014 10:54 AM
Install compression releases or change the cams? Reddobe1 Engine Related 9 04-20-2014 11:27 PM
NEW S&S No Compression Cams. gabbyduffy Engine Related 18 02-10-2011 04:14 PM
