Hayden M6 BT07 - Road Glide Forums
post #1 of 25 (permalink) Old 06-01-2013, 08:32 PM Thread Starter
Hayden M6 BT07
I might go into the Primary area this fall and make some changes. Has anyone ever used this tensioner? If so give me some feed back.
Nevadasun
post #2 of 25 (permalink) Old 06-01-2013, 08:52 PM
I just got one, haven't even installed it yet but plan to do it before SWIII. I've read many good reviews on another forum, nothing negative, I'll be doing my comments in a few weeks.
post #3 of 25 (permalink) Old 06-01-2013, 09:07 PM Thread Starter
I look foward to your comments. Perhaps our paths will cross at SWIII.
post #4 of 25 (permalink) Old 06-01-2013, 09:20 PM
FLTR2008Trike's Avatar
I have one installed. It works great. Keeps the right tension on the primary chain and It compresses when you rev the engine.
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #5 of 25 (permalink) Old 06-01-2013, 09:21 PM
tdkkart's Avatar
Yep, works as advertised, this is my 3rd bike with the Hayden tensioner.
The new style OEM ratcheting tensioners are better than the older ones, but have a nasty tendency to over-tighten.
tdkkart is offline
post #6 of 25 (permalink) Old 06-01-2013, 09:37 PM
panhead's Avatar
Got one on my bike, works great, constant tention on the chain, no slap feeling when you throttle on let off and throttle on again, great upgrade!
2011 COOL BLUE PEARL FLTRX , 120R,
too much to list...
panhead is offline
post #7 of 25 (permalink) Old 06-01-2013, 09:56 PM
staush's Avatar
hayden
Installed a Hayden on my 97 Road-king. Traded bike in at 50k and never a problem. Put the Harley ratchet type on my 05 glide at about 10k and at 45k the bearing between clutch and tranny started to go. The Harley one kept the primary chain too tight. On my 011 I pulled the stock tentioner off at 1k and put on a Hayden.If your bike has 30k plus I hope it"s not too late for the bearing. The stock tentioners are way too tight. At $100.00 the Hayden is well worth the money and piece of mind.
staush is offline
post #8 of 25 (permalink) Old 06-02-2013, 12:38 AM
Desertwndrr's Avatar
Three bikes, three BT07's. Very good upgrade.
Desertwndrr is offline
post #9 of 25 (permalink) Old 06-02-2013, 12:53 AM Thread Starter
Maby I'll go ahead and order this thing. The bike now has 36k.....
post #10 of 25 (permalink) Old 06-02-2013, 03:09 AM
You'll be happy with it. Give it a few miles to set in. Some folks say that there is a whirring sound for the first few hundred miles, but I haven't noticed it.
Hayden M6 BT07 JacktheBagger Aftermarket Accessories 29 09-22-2015 08:53 PM
Hayden M6-BT07 Primary Chain Tensioner quikcarl61 Sold 4 04-18-2015 09:47 PM
Hayden M6-BT07 modot66 Parts for Sale 1 02-14-2014 06:21 PM
Hayden M6 BT07 New in Box longrides Sold 5 08-02-2013 09:19 AM
HAYDEN M6 BT07 Installed,....Pics Nevadasun Engine Related 11 06-18-2013 09:03 PM
