Corrected Valve Geometry - Road Glide Forums
View Poll Results: Which Corrected Geometry Support Plates Would You Use?
Baisley 0 0%
Woods 0 0%
Other 0 0%
Voters: 0. You may not vote on this poll
post #1 of 7 (permalink) Old 06-05-2013, 09:18 AM Thread Starter
BlackDangerous's Avatar
If you had the choice of Baisley Corrected Geometry Support Plates or the Woods Corrected Geometry support plates which one would you take? Why or why not? If neither, then which one would you use? Application is for a 117CI-124CI power house. Thoughts?
BlackDangerous is offline
post #2 of 7 (permalink) Old 06-05-2013, 05:44 PM
Either.
If I understand correctly (and that may be pushing the envelope a bit...lol) these plates will help center the pushrod in the center of the pushrod tube to prevent rubbing. But to truly "correct the geometry" requires more than this, it requires setting valve protrusion, spring height, and probably several other "buzzwords" even I couldn't explain.
Baisley explains it better on his site but it involves setting up the valvetrain so that at mid-lift of the cam the rocker is at 90 degrees to the valve stem. This reduces side-loading of the valve (longer life of the guides I would think). Obviously Baisley can do it but there are several good head porters that are capable of this process (WFO Larry and Don Dorfman at Dewey's are the first two that come to mind).
gtnot is offline
post #3 of 7 (permalink) Old 06-05-2013, 06:25 PM
FLTR2008Trike's Avatar
Originally Posted by gtnot View Post
Either.
John @ Torque Inc is another head porter that would be a choice to consider
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #4 of 7 (permalink) Old 06-05-2013, 11:28 PM
unbalanced's Avatar
Then there is the answer that you possibly dont really need this at all. If it was such a problem/concern wouldnt S&S, Jim's etc have already addressed it. When I have bought my S&S motor they recommended the HD plate. /shrug
Might want to add to the poll to not need one.
-Unbalanced
He who laughs last thinks slowest.
unbalanced is offline
post #5 of 7 (permalink) Old 06-06-2013, 06:29 AM
Unbalanced took the words out of my mouth.
We have used Del West valve blanks, machining to the dedicated lengths etc, with lash caps to set up various engines over the years, but for a street engine? No.
Scott
Hillsidecycle.com is offline
post #6 of 7 (permalink) Old 06-06-2013, 07:57 AM
prodrag1320
Guest
Posts: n/a
with 99% of street motors theres no reason to worry about it,when your getting into the .675+lift area is when it starts coming into play.our gas drag bikes where running close to .900 lift cams & correcting geomitry was a big part of motor set up
post #7 of 7 (permalink) Old 06-06-2013, 09:30 AM Thread Starter
Thank You for actually answering that.
Geometry (rise,pullback,etc) of stock bars hometoast Controls & Handlebars 6 03-27-2014 12:18 PM
SAFETY TIP: Geometry and Lights DOOFUS Safety Area 9 10-15-2012 11:30 PM
FLTRX Geometry THEMASTERDESTROYER Road Glide Specific Discussions 9 01-04-2012 10:15 PM
F'n Murphy's Law - rear suspension air valve Timinfla2 *General Road Glide Discussions/Pictures 7 05-27-2011 02:57 PM
83* Valve Stems... FLTRI *General Road Glide Discussions/Pictures 21 03-29-2011 08:09 PM
